Question about IFB Washing Machines
Ifb washing machine
Showing 'AC lo', what should we do?
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
reddyanantha
  • 205 Answers
SOURCE: my washing machine says LO how can i unlock
mam there is an error in the lock check the contacts of the lock by inserting a tester or a screw driver into the female lock and see the indication if the lock is good this test will work on that and if its not working so please change the lock(female lock).
Posted on Sep 07, 2009
SOURCE: there is a cockrach in the idicator of my IFB
ewww! If I had cockroaches I would MOVE! Gross!
Posted on May 02, 2010
  • 414 Answers
SOURCE: IFB washing machine dryer not working
can you supply the enr?
first port of call is the overheat stat, switch off mains remove lid and in the middle top of the unit there should be a metal chamber that houses the dryer heater, somewhere there, you will see a stat that should have a reset button on it, if you press the button and it makes a definate click, it was tripped. There are some reasons for this, you may be stopping the dryer early and not letting it do the last 10mins which is a system cool down, the fan is not operating or slow, the unit is not draining properly (check pump filter) or you are trying to dry more than 2.5kg (half a load).
Good luck.
Posted on Jul 08, 2010
  • 6277 Answers
SOURCE: my ifb washing machine digital
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 13, 2011
Ifb washing machine showing DOOR NOT CLOSED
Visit the sites linked here for more details about the error cddes to many brand washing machine, and dish washers.
http://electrotechnician.blogspot.com/
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Aug 10, 2016 | IFB Washing Machines
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
My ifb washing machine is showing dp error
Jul 05, 2014 | Washing Machines
In IFB front washingmechain AC h1 error is coming what to do
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Jul 03, 2014 | Kenmore Elite 45986 Front Load Washer
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
I have ifb elenaa washing machine. my problem is that water can't enter or drain from machine .help
make sure the water is turned on at the faucet handle behind the washer.
Apr 20, 2012 | IFB ELENA
My washing machine says LO how can i unlock the door is opening but nothing is happening still showing LO
Sep 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
330 people viewed this question
Top IFB Washing Machines Experts
Raj Patel
ray gallant
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
