Question about Timex Expedition Watches
I m seeing a indiglo defect in the left upper side of the round dial, whats that??
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    I have a watch that I got from Sears Canada?. I need to know how to change the time. I got it in the summer of 2012. It had 4 buttons, mode (top left), indiglo (bottom left), set (bottom right), and s
    My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers
    Nov 04, 2012 | Watches
    Might light no longer works, had battery checked and it is fully charged. Please advise
    the indiglo of your watch is probably busted, you had to replaced its dial. the the battery has been checked but not the watch by a new battery? try to check the watch by a new battery. if still not lighten up check the connection of the button it probably cannot connect the connections of the light. i hope this advise will help you a lot.
    Sep 08, 2011 | Timex 2D421 Stainless Steel Perpetual...
    Trying to set time on Timex 1440 sport with mode button top left, start/stop upper right,adjust bottom right,indiglo bottom left..no instructions match or work.
    press and hold the mode button until the digits blinks then press it again once, (digit that are blinking is changeable) use the "start/stop button to choose what will you change and adjust buttton to adjust it. if your done, press the mode button again once.
    i hope i had been helped you.
    Aug 10, 2011 | Timex Watches
    HOW TO SET TIME IN INDIGLO WR 50M WATCH
    Venkataphani,
    I hope the following instructions help you to set the time on your watch.
    1. Press the "Mode" button on the lower left-hand side of the watch twice to change the time.
    2. Press the "Start/Stop" button on the upper right to select the hour, minute and second in setting the time. Also use this button to select the date.
    3. Press the "Spl/Reset" button on the lower right side of the watch face to change the number for each selection.
    4. Press "Mode" again to set the time.
    Please let me know if you should need an further information. If you find this helpful, please remember to rate it.
    Enjoy your watch!
    --Sandy
    Apr 30, 2011 | Watches
    I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
    Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    Indiglo has died on over 10 of my Timex watches
    If they have replaced that many watches in that short period, I'm going to say that it isn't the watch.
    Timex watches are equipped with some of the largest and strongest batteries in the industry and have some of the best reserve potentials. Have you ever replaced a battery and did it make a difference?
    Do you use a magnetic bracelet or work around strong magnetic fields - either of which can deplete a battery - generally in about four months? If so, put the bracelet and watch on opposite wrists. This is usually not a problem with a digital watch. I suspect it's because the magnet makes the analog movement work harder and depletes the battery faster.
    And some people just can't wear a certain watch. My mother is one of them. There is something electrical or magnetic about my mother that keeps her from wearing a mechanical watch. When I was a kid, the only watch she could wear was a green plastic Davy Crockett watch.
    And 50 years ago, my left handed brother gave me his hand-me-down Timex when it quit working for him. I put it on my left wrist and got several more years of wear out of the watch. I think he wore out the movement on one side wearing it on his right wrist and I wore out the jewels on the other side wearing it on my left wrist.
    Jun 12, 2009 | Timex T5E921 Ironman Triathlon Sports 30...
    Timex T49271 Expedition Indiglo button dead?
    There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
    Hope it may helps you;
    Regards
    VOTIT
    Mar 23, 2009 | Timex Expedition 40141 Wristwatch
    Eliminate half moon from dial of a Timex Ironman Triathlon watch
    You need to hold down the Indiglo button for 4 seconds. The half moon means that night mode is activated, and it will tuirn itself off in 8 hours (which I'm sure you know by know, seeing how it's been 5 years).
    http://www.sportswatchinformant.com/timex-ironman-watch-night-mode-feature/
    Nov 13, 2008 | Timex Ironman Triathlon Sleek 50 Lap 5G301...
    Watches Logo
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Mark Schmit
    Mark Schmit
    Carol
    Level 1 Expert
    Are you a Timex Watch Expert? Answer questions, earn points and help others
