Question about Motorola Mobility RAZR V3c Cellular Phone
Razr v3 cell
New phone. Was working fine, Key pad will not work. Can not dail out at all. Can receive calls. Can turn phone off and on, Thats all it will do.
  • 34 Answers
The key pad may need cleaning on a replace ment or becuase of usesage it over work you can on the phone off take the battery out for a few days then try it if not try the first two
Posted on Oct 01, 2007
  • 29 Answers
Is your phone been dropped? or in contact with liquid? Check our local service center if they could find any phgysical damage on the phone.
SOURCE:
AFTER SWITCH ON , DISPLAYS ," ENTER UNLOCK CODE" BUT KEY PAD DOES NOT WORK.
first type!you use your mobile more than 250 hour this kind of problem came! for that you want to install new software for your mobile!second think is if you play games in yur mobile this problem came!
Better think is you format your mobile and try to put new software to your mobile!!!!
Good Luck..
Jul 17, 2008 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Tech support
the problem of the two phone is in their flex, you can just replace the flex, thats it,,,
Jun 09, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Only the End key works
download the set of programs from that link i sent you, if u hav installed drivers for ur v3 as yet, jus plug in the cable n folow the prompts n select the folder called p2k drivers, afer that restart ur pc, install rds lite 2.4 n plug ur fone back in n browse for the small in the the key pad folder n flash ur fone... that shud fix ur keypad issue
http://www.4shared.com/file/40625107/d1513354/key_pad_fix.html
Mar 12, 2008 | Motorola Mobility RAZR V3
New razr v3
chane the flex cable or try and reflash the phone firmware.
Dec 06, 2007 | Motorola Mobility RAZR V3
Razr Key pad not working
hi
it seems you have a prob in its keypad flex... try changing it and your prob is solved...
Oct 10, 2007 | Motorola Mobility RAZR V3
Key pad is frozen
is your phone been dropped or wet? check local service center near our place.
Sep 20, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Razr - Keypad Doesn't Work
My phone developed the same trouble............ Removed battery and SIM and blew dry air into anyhole I could find, put it back together and has worked ever since.
Thanks for the tip
Jun 25, 2007 | Motorola Mobility RAZR V3
Key pad Does not work!! HELP
ok did you change sim cards lately? How old is your phone? did you get it wet at anytime? If you dont get it fixed soon call cingular and they should be able to help you......
Jan 14, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
