Question about ASUS A7V400-MX Motherboard
A7V 400MX ASUS Mother Board: Problem
Recently, my computer is not hanging on.
The cpu's fan is rotating, the light of the motherboard is lightning...
Even the light of the cd drive is lightning, and the eject button is working just fine(the case goes out, and goes in).
BUT, no signal of the HD, and worse, no sinal of the motherboard work properly.... nothing is being showing on the screen, the light of the monitor just keep turning on and turning off.... and not even the bios shows up.
Could you help me? What could it be?
  • Gary Holmes Jr. May 11, 2010
    what allo have you installed into the computer and did it work before you installed something also has there been any power spikes or storms in your area
I had same thing - was power supply,,,,replaced and all fixed, now boots properly everytime
Posted on May 19, 2009
SOURCE:
Had a lightning strike last night that shut the computer down. With a "snap" sound. Rebooting goes through XP Startup screen, then only desktop wallpaper shows. Mouse moves, nothing obvious to me in the...
power surges generally damage power supplies or mother boards
smart operators use surge protection board or UPS unit s to lessen potential damage
Take it to a repair shop for a diagnosis
Nov 01, 2017 | ASUS A7V600 Motherboard
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
Had my motherboard changed by local repair shop. Both fans are now running constantly & it is deafening, also power light no longer comes on and was told it was "no big deal". Have 2 like computers,...
Ok so what fans? the case fans? the cpu fan? The power supply fan should always run. The case fan can be wired to the mother board and do an speed step system (slow to fast) depending on heat, same with cpu fan. As for the power light its just an matter of pluging in the wire from frount panel to the mother board pins for pwrled. Asus has an download for your board to get the pin outs.
http://dlcdnas.asus.com/pub/ASUS/mb/socka/sis741GX/e1766_a7s8x-mx.pdf
Feb 25, 2010 | ASUS A7S8X-MX Motherboard
After changing power supply, motherboard still doesn't start
Asus huh.. okay your problem is one of the following ^_^
1- either the CPU Fan is not attached well or loos, that will cause the CPU to melfunction
2- BIOS damaged, well if the mother beard doesn't start at all then this is your problem, Change the BIOS at any ASUS local agent
3- CPU damaged, if the computer fan starts working but the screen doesn't and you are suer the fan is tightly and correctly attached.. then this problem remains in CPU.. @[email protected] I really hope its not.
Jul 16, 2009 | ASUS P5P800-VM Motherboard
Need to change mother board
WRONG ON THAT I HAVE ALL THE BOIS INFO YOU NEED.
WWW.lemig.umontreal.ca/bois/bois_sg.htm
www.ping.be/bois/numbers.shtml
www.allelec.com
email: [email protected]
www.unicore.com
go on line type in
update bois or upgrade bois
enter
typing in the bois name and date will tell you about any update or chacges and how to get the updates for free'
bois download drives my work also
rod
ps if you want mother information buy the new cpu magizine [ computer powers issue march 2009}
give you mother boards cpu cooling options cpu venders and option and more info check it out
rod
Feb 04, 2009 | AMD Asus A7V-ML Socket A MicroATX...
The mother donot boot up if the cpu in its maximum speed
Computer hanging means it is unstable try 2.2 ghz instead and use a benchmark program off net to test system
Jan 18, 2009 | ASUS P4XP-X Motherboard
DDr or Dual Channel Ddr
From the manual:
2 x 184 pin DDR DIMM Sockets support up to maximum 2 GB unbuffered PC 2700/2100/1600 non-ECC DDR SDRAM memory.
So, to answer your question, for your particular motherboard, no. However, to dispute the other poster, Dual channel is better than regular DDR. It's just your motherboard does not support it.
Jul 03, 2008 | ASUS A7V400-MX Motherboard
Asus 945 motherboard is in stand by mode. When I power on , the LED of mother board is glow The cpu fan just jurking and stop. And the LED of motherboard is still now glow.
Hi kausik, that green led you see on the motherboard is just letting you know there is power to the board. (This is normal).
You'r CPU fan jerking & stopping is a bad thing & has nothing to do with standby mode. Your CPU fan needs to be replaced.
There are a bunch of Asus 945 boards, just click the link to see.
http://support.asus.com/download/download.aspx?SLanguage=en-us
If you are able to remove the fan from the heatsink than you may be able to buy a fan from here.
http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=99&name=Cooling-Products
Most people replace both heat sink & fan.
Have more questions, feel free to ask.
Good Luck!
Mike
Apr 18, 2008 | Intel Motherboard
I want down load A mother Board Driver
type in your model number on the left.
A7V400 it will come up with 2 options.
Dec 01, 2007 | ASUS A7V400-MX Motherboard
MicroATX motherboard work but the monitor shows a black screen.
I assume the monitor is turned on? Try the monitor with a known good computer to verify it's OK. I believe this board has AGP video. Verify that it's properly seated, or try another board.
Sep 13, 2007 | AMD Asus A7V-ML Socket A MicroATX...
ASUS A7V400-MX Motherboard Logo
273 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
