Topfield trf 7160 manual
There was a power outage and I have lost the ability to record any of the programs. The signals go to the set top box but it doesn't actually record.I can't find a way to remedy this in the instruction book. Thanks Bev
  • 70 Answers
SOURCE: Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Posted on Jul 28, 2008
SOURCE: Problem connecting Samsung DVD-HR737 DVD recorder to Set Top Box
I had the same problem, if you go through the channels from your DVD-R remote it should give you the option AV-1 and then AV-2 ? on mine it's AV1 (test it out first and you have to watch what your recording) then it should record from the cable box
worth a try?
Posted on Aug 24, 2008
  • 4 Answers
SOURCE: LG DVD Recorder- Clock settings Model RH277H
The clock settings will only be retained if you power down the unit via the On/Off button on the remote or on the unit i.e. put the unit into standby mode. If you switch off mains power the clock settings are lost as there is no backup battery in the unit. Power consumption on standby is negligible.
Posted on Jan 10, 2009
  • 7 Answers
SOURCE: Record using emerson dve/recorder
try this
http://www.emersonaudiovideo.com/pdf/om/EWR20V4.pd
or if i didn't provide the right model, go to this page, and enter the model.
http://www.funai-corp.com/support/manuals.aspx
hope it helps
Posted on Feb 24, 2009
SOURCE: Need a copy of the instruction manual
how to manually tune a digital set top box tcl dst 8313
Posted on Aug 08, 2009
5 digit remote code for topfield trf-7170
29560,29153,22014,22917. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 23, 2015 | Onkyo Televison & Video
Our Topfield TRF 7180 records ok but pixilates and then keeps skipping when playing back. Can anyone help with is problem or do we just need to replace it? TIA
It may be a fault with the hard disk which does the recording, but I'd check the signal strength to the unit first. You need a good signal for reliable recording, one which does not drop in and out. You should use quad shield coax cable right from the aerial to the back of the Topfield
Aug 30, 2014 | Televison & Video
Howto get beter quality reproduction from a TopField TRF-2400 Set top box
Use the HDMI connection for best quality (do not upscale). If this is not possible, use the Component connection. The poorest quality comes from the Composite connecton.
Jun 06, 2014 | Televison & Video
How to scan channels on topfield pvr
See page 16
Installation > Service Search
It's advisable to do a reset first - Installation >
System Recovery > Reset Service List
Feb 17, 2014 | Televison & Video
Topfield problems
when I try to install I get to the search part and it always freezes at 66%, has anyone else had this problem and what did they do to fix it ???
Jan 18, 2014 | Televison & Video
Topfield trf-2100 manual
My TRF-2100 requests a password, I have never given the machine one.
The default 0000 does not work.
How do I reset
Apr 22, 2013 | GPS
PVR problem.
We have now used warrantee 3 times to get a PVR that does not freeze. None were your brand, but the reboot process was to cut the power to the unit to reset. On each one we took back, this became progressively worse and such a pain. The unit we have now is a Topfield TRF-7160. The only catch is it only has 500 gig drive which is a bit limiting but of all the things that annoyed us this has the least. You can also preset 5 minutes ealy start and 10 minutes on the back end to beat channel 7 slackness on program times. I loves the 128 speed fast forward also to push the ads.
What I am saying is they are very flakey items it seems.
Just by the way - we went through a antena problem with the mast head amplifier when the amps power supply failed, Just check that also.
Dec 14, 2011 | Humax Televison & Video
I have a Yamaha RX-V667 Receiver and I need a code for the Remote Control to operate my Topfield PVR model 7160 (Australian release). Yamaha have not published any codes for any Topfield products. Do you...
just bought a Topfield trf-2460 PVR and I have got everything working except the remote control (that came with pvr) sound funtion. I can record and playback with the audio working fine but even after setting the TF remote control to work on the TV funtion, it just doesn't like it, except for the mute button, that and the off function. Any suggestions would be appreciated. Joe
Oct 24, 2010 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
