Question about Superex Canada Ltd Emergency Jumpstart Mobile Power Supply Rechargeable
What is the input power of superex emergency jumpstar
Input power
I have a Superex 100W power inverter. I want to see if I can plug into cig lighter then a standard extension cord and lamp into it
In order to produce 100 watts at 120 volts, the current will be 1.2 amps. But if you are producing that power from 12 volts input, the current will be at least 10 times the output current, and that would be at 100% efficiency, which is impossible to achieve, The efficiency could be assumed to be around 70% though, meaning that the current input required to produce 100 watts at the output would be somewhere around 13 amps. That's a lot of continuous power drawn from a cig. lighter, and the load might blow the fuse or breaker for that circuit.
Dec 29, 2016 | Superex Electronics - Others
I'm lost I have a superex slim power bank 2600xmAH I try charging and the percentage of power remaining goes down, I'm not doing it right. There is in & out at one end for connections, what!!!
in is for recharging the power bank and please note that it takes time to charge. and out is for your charging your devices when the bank is charged. yes you can use the same cable for both by inverting. and do not loop i.e connect the in to out whatever you do
Feb 17, 2016 | Computers & Internet
How to recharge superex jumpstart/compressor
Plug in the cord with the switch off. If the battery is still good in the unit then it will take a full day to charge. If you charge it for a full day and you still have nothing the battery is bad. If this is a new unit, check to see if it is under warranty.
Sep 06, 2014 | Superex Canada Ltd Emergency Jumpstart...
How do i charge it
On the back there should be a cover over a plug. Lift the cover and plug it in with a single outlet extension cord.
Jun 27, 2014 | Superex Deluxe power station with air...
2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Jan 02, 2014 | Superex 50-373 2500 Watt 12 Volt to 110...
What is the size of the glass fuse for the 59-204 400W power inverter ?
Hi
If it is the secondary fuse it would be 3.15amp or 4amp
Regards
Jan 31, 2011 | Superex #59-204 400W DC Power Inverter
Jumpstar secure 11 plus know how to put things(photos) on but do not know how to put them back on computer to be printed etc.
Your photos should be still on your hard drive to work with , copying to the flash drive only leaves them intact on the main drive.
Aug 30, 2008 | Computers & Internet
Superex Canada Ltd Emergency Jumpstart Mobile Power Supply Rechargeable Logo
46 people viewed this question
Top Superex Canada Ltd Computers & Internet Experts
David Payne
David Payne
Are you a Superex Canada Ltd Computer and Internet Expert? Answer questions, earn points and help others
