Question about HP Photosmart MZ67 Digital Camera
Lens Stuck open on Mz67 hp camera Error code Mz60-022
The Camera Was dropped !
Can i Fix this myself ?
I have already Partly disassembled the camera
    Scholar:
  • 54 Answers
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Posted on Nov 24, 2009
SOURCE:
When power ON the screen displays"Lens Error!" & lens does not open.
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 04, 2010 | Nikon Coolpix L1 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
Lens will not retract
When the lens will not retract and camera is not functional (no picture ondisplay, and does not shoot) , and you already tried replacingbatteries with a new fresh set (ensure please) , and then restartingcamera with no memory card inside, then camera is faulty.
Try aneasy fix by pushing gently the lens (do not force them, just help them)while you turn off camera at same time. Try also switching the modeselector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair frommanufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Dec 22, 2008 | HP Photosmart M425 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 28, 2008 | HP Photosmart MZ67 Digital Camera
Lens Stuck
YOU CANNOT REPAIR THIS SOPHISTICATED CAMERA YOURSELF!!
I guess pushing the lens inside may have made the problem worse.
I follow a rule- if you drop an electronic equipment and a problem occurs- it usually takes a professional repair!
For all you kamow there is a minor problem in the camera, like something stuck inside or something like that. and most certainly you will aggravate the problem by trying to do it yourself..
do post when you get it repaired, for all of us to know what goes wrong when lens gets stuck..
take care
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Lens Stuck
same thing happened to me. Honestly you have to push the screen in as a hard as you can, I was afraid this would break it(honestly it is already broken) but it went right in!
May 21, 2008 | Nikon COOLPIX S200 Digital Camera
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
E18
error code e18 means that the focus motor gears a jammed, dirt or grain of sand in them. you can try to fix it by gently banging the camera on somthing soft, their are also instructions on web on how to disasemble and fix this fault. BUT unless you have some skills, the right tools and conditions i would not attempt it. leave it to the experts
Sep 17, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
HP Photosmart MZ67 Digital Camera Logo
768 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
