Canon correct paper load paper ltr plain - Office Equipment & Supplies
5 Suggested Answers
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Posted on Nov 14, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
iservice
  • 318 Answers
SOURCE: paper cassette error
This meen the paper dial selector in the drawer is set for letter size paper,set it to the correct envelope size.I suggest you use the manual bypass for the evelopes.
Posted on Sep 25, 2009
Ir 2420 canon printer displays load correct paper LTR plain
check sliding plastic paper size device in bottom of paper tray is not on LTR if it is meant to be A4
Mar 24, 2016 | Canon Office Equipment & Supplies
Canon MF3220 LOAD CORRECT PAPER CASSETTE:LTR
the ACE Thanks its work for me
edrickkp
TANZANIA
Mar 29, 2012 | Canon Office Equipment & Supplies
Our Canon imageRUNNER 2270 is copy/printing sidways instead of normal. what happened?
I would look to make sure the paper tray's are set correctly in the paper trays... There is a knob that moves at will.... just kidding... Make sure that when you press on the diplay for paper size's, that if it shows LTR make sure the paper is in the tray going the short way.. LTR or you may have the paper tray set for LTR-R and you have the paper in the tray as LTR. I believe that the paper trays are set wrong. You may have figured it out already.. Good Luck
Nov 29, 2010 | Canon imageRUNNER 2270 Copier
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper cassette error
Sep 25, 2009 | Canon imageRUNNER C3200 Copier
Canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Jul 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
How to scan legal documents on Canon MF5770?
This information is available on CANON WEBSITE
Unfortunately, they imbed the text in javascript, and there is no way to link or c/p the information here. Try THIS HYPERLINK to take you to the exact page.
Enter your model # in "search knowledgebase" at the above link.
Type PAPER SIZE
You will have a clickable link that says How do I specify paper Size and Type.
Instructions will appear.... starting like this... (i used C/P, and it may not come out slearly after I submit this answer)
Issue: How do I specify the paper size and type?
Solution: Specifying the Paper Size and Type
  • When making copies on LTR-size paper after having continuously copied on paper smaller than LTR-size paper, the copies may be dirty. To prevent copies from being dirty, wait about 1 minute before making copies.
  • The paper in the multi-purpose feeder is fed prior to the paper in the cassette.
  • The settings changed in the Menu do not return automatically to the settings you set previously. Change to the previous settings again if necessary.
  • When making copies of a small size or heavy paper*, etc., the copy speed may be slightly slower than usual.
    *The paper type should be selected in the Menu.
  • If you intend to make a copy and print with a thermal transfer printer using the same sheet of paper, make the copy first. Failure to do so may make copies dirty or cause a paper jam.
  • When copying onto transparencies, remove each transparency from the output tray as it is output.
  1. Press <Menu>.
  1. Press <Menu>.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
666 people viewed this question
k24674
jasbo
jasbo
