Question about Kenmore 24 in. 16293 Built-in Dishwasher
Kenmore 655 13443k900
Sometimes it drains and sometimes it dont
Kenmore refridgerator with top freezer is leaking water from bottom of vegetable drawer
There's a drain line for the defrost cycle that's likely just plugged up. Sometimes you can find it from the drain pan located under the fridge and if you snake a long piece of weedwhacker line or something similar up the tube, you can sometimes clear it.
Good luck.
Mar 19, 2015 | Kenmore Refrigerators
Why won't my kenmore 400 washer spin out?
Sometimes the drain pump goes bad which prevents the water from draining and then spinning. If this isn't a direct drive model then a simply fix to replace the drain pump and belt. Good luck
Jul 10, 2010 | Kenmore 400 6942 Dryer
Periodic water leaking from Kenmore Elite K701
hello Adrian. I am suspicious that the standing drain pipe behind your machine may sometimes over flow. To find out, pack some dry newspaper around the drain hose where it enters the drain line behind the machine. If that newspaper gets wet you will know that the drain is sometimes overflowing. If that is the case, snake that drain or force a garden hose down it and run hot water thru it for ten minutes. J.
Jul 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher 16029 does not drain
There probably is something in the pump... sometimes you can take the drain hose off the sink end and run water backwards into the dishwasher and dislodge the problem...
Sep 23, 2009 | Kenmore Dishwashers
I have a kenmore eco cycle front loader...E20 comes up
Should be still under warranty dont hesitate to call service tech. If your already having problems then you see what you have to look forward to. I think if they have to come out so many times they replace the washer not sure about that but I would call them
Sep 01, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore model 665.17609300 type 575-0 Dishwasher will not drain. Float valve and drain solenoid ohm out correctly. Drain hose is clear. Suggestions?
Check your air gap on your drain. It should be located on or around your sink. Sometimes food and other trash will stop it up and will not let your dish washer drain. The cap should unscrew off .Good Luck.
Aug 13, 2009 | Kenmore Dishwashers
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 16293 Built-in Dishwasher Logo
43 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
