SOURCE: There is no sound on my Technika Digital
Things to check;
Make sure your scart plugs are pushed all the way in both at the receiver and the tv.
Make sure the volume is turned up on the receiver and the mute button hasn't been pressed.
Make sure you have the correct av input selected on the tv (circle or square with an arrow on it on the tv remote control).
My money's on the scart plugs.
SOURCE: Have problem with Philips On digital terrestrial
Try unplugging the unit from the wall, unplug the Aerial cable from the box. Plug the mains back in and switch on. Do a channel scan (with the aerial still unplugged). Reconnect aerial and do another scan. With luck it will have flushed the old settings and pick up the channel changes.
Regards
Zahc
SOURCE: Have plugged in digital terrestrial receiver to tv
Check the scart connections are in tight (if that's what you are using). You may also want to try another cable. Also, make sure you have the correct input selected on your TV; the button on your remote should be either a circle or square with an arrow through it and possibly labelled source or AV.
Regards
Zahc
SOURCE: Unable to rescan channels AWA STB 262 set top
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
