Question about Caterpillar E70B Excavator
Cat E70B excavator
Lots of metal dust comes to the hydrolic tank cant find how, oll the rotating parts are ok, cant find where metal dust came from
    New Friend:
  • 17 Answers
Evacuate the hydraulic tank and clean with kerosene.Get as much fluid out of the machine as possible. Replace Filters and if it builds back up with metal SELL SELL SELL it or your in for some big money repairs.
Posted on Aug 05, 2013
17d excavator as it warms up I lose power in my hydrolics and they start to overi ride each other almost
this can be several things wrong , but id start by the basics , new fluid , new filter , check/clean strainers then move on to more serious things like directional control block , and pump/bypass vlv also depending on what type of spool locks you have on your directional control block vlv's , a internal leaking cylinder can do this as well
Feb 02, 2017 | Caterpillar E70B Excavator
Why won't my excavator stop overheating?
Search Results
    Solving Hydraulic System Overheating Problems
    www.machinerylubrication.com/Read/680/hydraulic-overheating
    Overheating ranks No. 2 in the list of most common problems with hydraulic equipment. Unlike leaks, which rank No. 1, the causes of overheating and its ...
    Cat 320 overheating - Heavy Equipment Forums
    www.heavyequipmentforums.com/showthread.php?2828...overheating
    Mar 28, 2007 - 15 posts - ‎10 authors Anyone here have a problem with a Cat 320 overheating? ... that many heatingproblems in excavators are caused by hydraulic problems. 5T Excavator KX161-3 overheating
    Apr 22, 2013
    john deere 270D excavator over heat
    Aug 1, 2011
    cat 305CR overheating issue
    Jul 23, 2011
    cat 312 overheating
    Jul 31, 2008
    More results from www.heavyequipmentforums.com
Oct 14, 2015 | Cars & Trucks
Do I have to split the track to install new bottom rollers on my E70B?
If you remove the plug for the grease cylinder on the idler arm and squeeze out the grease manually by pushing the pulley wheel in, you can relates enough tension on the track to sag it down and maybe remove rollers. Or you can remove the track this way with a little manual labor without splitting it.
May 30, 2014 | Caterpillar E70B Excavator
E70b shutoff solenoid not working
Some of the e70's are shut off by the throttle lever. push it all the way farward for a manual shutoff
Apr 15, 2014 | Caterpillar E70B Excavator
I have hydraulic oil in my radiator, e70b
I am not familiar with that particular machine, but I believe it would more likely be diesel or motor oil, unless of course there is a water exchange hydraulic cooler. If there is, check that for a leak to the coolant. If not, I would check compression on each cylinder, and/or look for signs of a blown head gasket. Other possibilities are probably more serious than even that. I hope this is helpful.
Mar 25, 2014 | Caterpillar E70B Excavator
Swing so slow
Check Turn Table Oil Level. Rebuild if necessary.
Jan 27, 2013 | Caterpillar E70B Excavator
Leaking hydraulic oil around the turntable
The seal units at the turn table are worn or there are grooves worn around the sealing ring.. It is common for this area that is subject to such movement in the worst possible conditions of dust and other contaminents
Jan 16, 2013 | Caterpillar E70B Excavator
211 cat excavator hydrolics working slow
When did you change the hydralic fluid last? How about the hydralic fluid filter or filters? Is it cold where you are, if so you should be using winter rated hydralic fluid. Also, you may have to turn up the engine speed to get the hydralic pump to put out more volume at a greater pressure.
Jan 13, 2013 | Televison & Video
E70b excavator starts to miss under load
Hi have u tried breaking the fuel line after the primer pump 2 see if u hav a strong flow using the pump. If not u might hav blockage at bottom of fuel tank and it may require clean out?
Jan 07, 2013 | Caterpillar E70B Excavator
Cat e70b wont start
Check the glo- plugs are working and check that the batteries are spinning the motor fast enough. Diesel engines need quick revs to heat the combustion air hot enough to ignite the diesel spray. If the engine is old you may need to have the injectors done as they have to atomise the fuel and not spray it in
Aug 11, 2012 | Caterpillar E70B Excavator
Caterpillar E70B Excavator Logo
822 people viewed this question
Top Caterpillar Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Caterpillar Garden Expert? Answer questions, earn points and help others
