Question about Konica Minolta Office Equipment & Supplies
Co545 atds sensor code
My atd 37001 welder was welding along fine when it just stopped arcing I assume a part burnt out but which one and how do I find the part?
Check a fuse or circuit breaker. The breaker may reset it self when it cools down. The rectifier may be bad or the transformer opened.
Oct 20, 2013 | Atd Tools (ATD3130) 130A MIG WELDER 115V ...
Hi, Can you tell me why my ATD 5953 beeps some times. Thanks. Roger
Yes, it will beep warning you it is peaking the power. For example, let's say your running a computer, and maybe a small tv or something, then let's you have motor off and units surge or require more power , inverter will peep to warn you, that your peaking power and pulling more power than battery can supply /via alternator put out. I had a 3500 power inverter in a semi truck, when I used to run microwave, especially with motor not running it would do that, when microwave would surge for heating. Make a long story short, just when it beeps, it's saying need more power captain!! Thanks mike from fixya.
Jul 16, 2011 | Atd Tools ATD-5953 1000 WATT INVERTER
Need codes k14tk205Q-G
Many codes here:
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
Or try the last three(or four) digits from the TV's serial number. That worked with my old ATD TV after all else failed.
Let me know if it is on the serial number please. Would be good to know how common that is.
Oct 08, 2010 | Televison & Video
How to readR134A ac manifold gauges
The blue gauge is the low side. It should read between 30 to 60 PSI depending on temprature. The red is the high side, and should read roughly 3 times the outside temp. Good Luck
Jun 22, 2009 | Atd Tools R134a Economy Brass Manifold...
Heating element atd-3737
You can purchase the parts from an online tool parts web site. Or you may wish to go to the Milwaukee tool website. They have a listing of local service centers that may have the part.
Apr 09, 2009 | Atd Tools Dual Temperature Heat Gun
Remote Control code for Accurian
I have a larger ATD TV set and after no luck with any listings I tried the last three digits on the serial number sticker. On mine it's 122. Well call me suprised, LOL.
Oct 16, 2007 | Televison & Video
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
