Question about Gigabyte GA-8SIML Motherboard
My acer aspire one has stucked on factory recovery mode, it has tucked when installing configuration for android on the 30/39
It has morethan 12hours now installing acer configuring for android
  • 3,799 Answers
If you are installing an Android operating system on an Aspire One you will need to make sure you have a compatible ROM image. I would suggest you try and install a Linux OS such as Ubuntu or Mint. The Aspire One was available with Ubuntu from the factory.
Posted on Jun 17, 2013
On my laptop aspire 5349 when i try to recovery factory setting the laptop installer starts services is stuck how to solve this problem.
I am guessing the laptop is a few years old now and not covered by warranty, it appears you have a corrupt recovery partition or the HDD is faulty which i suspect its the latter, need it checked as i think a new HDD is in order.
Jun 08, 2014 | Acer Aspire 9300-5349 Notebook
Acer aspire AX1430-EF30P will not boot stuck on BIOS setup
Unplug, remove battery, plug in, push on/off button use this procedure: http://yourbusiness.azcentral.com/recover-acer-aspire-one-19796.html To do a System Restore or a System Recovery, if you have a Factory Recovery Partition, you will lose all you date if you Recover to Factory Settings. A System Restore is preferable, to a date before the issue. If the HDD LED does not blink during startup it may be bad, remove and test. Use the "F" key to try a Safe Mode Boot or other options.
Sep 24, 2013 | Acer Computers & Internet
ACER REINSTALL STUCK ON INSTALLING CLEANUP 28/29
Sounds like the recovery disk when BURNT contains errors, you need the factory discs for your system
Jan 26, 2013 | Acer Upper Case Palmrest for Aspire 5336,...
Reinstalling windows os
Restoring your Acer back to factory setup will not bring back any viruses.
BUT you need the Acer recovery CD for your model laptop.
Acer Recovery CD is available from their WEB site.
http://www.user-guides.co.uk/acer/acerrecovery/acer.asp?keywords=acer+aspire+5250+recovery&recor=1
Feb 24, 2012 | Acer Aspire 5336-2283 Notebook
My Acer will not boot up. When I turn it on, it loads straight to configuring updates then restarts and goes back to configuring updates. Its a never ending loop. i can not start in safe mode nor do i...
Sounds like you have a corrupted Windows Update. Unfortunately if safe mode is not working, then your only option is to re-install the OS. Usually Acer laptops these days don't come with recovery disks. Instead they have a recovery partition built right in to the hard drive. Check in the manual for the hotkey to press to start the system restore when the system is booting up.
Jul 06, 2011 | Acer Aspire 3680 Laptop
Trying to restore acer netbook to factory defaults because windows won't start.however that option is'nt in console.I have only last known good configuration, or directory services restore mode (windows...
Insert your Operating System recovery CD then try to turn off the computer, remove the cables and battery. Then press and hold the power button for 8 secs. Reinsert the cables and battery. Press and hold F12 while turning on the computer. Select the CD/DVD ROM under boot device menu. Press any key to boot from CD. Then select English > then select Custom > then select Disk 0 partition. On that manner, your system will install fresh copy of your operating system and will restore your pc in factory default..
Aug 17, 2010 | Acer Aspire One A150-1049 Notebook
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Having completed a factory reset on my Acer aspire i have a solid blue box stuck on Installing e recovery It's running but nothing more!!!!!
OK you said Windows, but not if XP or Vista (presuming you don't have a way older version). Since you are saying "recovery" I'm going to presume Vista, since MS stopped shipping install disk after XP.
It's been 4 days, so I presume you are not still stuck in recovery mode, and can boot into Windows?
If so, try the free virus scan, reg fixer, etc from Microsoft at:
for XP: http://onecare.live.com/site/en-us/default.htm
for Vista: http://onecare.live.com/site/en-us/center/whatsnew.htm
(I was a beta tester for this, before it went public).
If you can't get into Windows (even safe mode) you will probably need to find someone with the install DVD (if it's Vista). Since it sounds as if there is either a problem with your recovery drive or a corruption of the recovery software/files itself.
May 17, 2009 | Acer Aspire 5050-3242 Notebook
Laptop system
Hi
Well this is a problem if you didn't make a factory disk nor backed up the system configurations then only thing that will work is to reinstall the operating system. Here is a trick that Acer will never tell you
press the on button and imedetly press ALT + F10 in this order ALT + F10 - ALT + F10 until it goes into recovery mode all the Acers that has 2 partitions have the recovery mode then click on recover to factory defult this will load the factory operating system + driversand applications
kind regards  Mervinh
Sep 22, 2008 | Acer Aspire 5315 Notebook
Gigabyte GA-8SIML Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
