Question about Sewing Machines
Singer sewing machine 2630 C how to oil it
How to oil singer sewing machine 2630 c
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
  • 43 Answers
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
Posted on May 06, 2009
  • 980 Answers
SOURCE: I would like instructions on how to oil my Singer sewing machine
You canb only oil the moving parts that you can see very lightly with WD40
Posted on Oct 29, 2009
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
  • 29 Answers
SOURCE: Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
http://homeappliance.manualsonline.com/manuals/mfg/singer/7442.html
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the manual...you don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
Posted on May 14, 2010
Testimonial: "Hi, thanks a lot. I don't know if it came with the oil, we assumed that it maybe needs oil (my father knew this from the old machines ;-) ) Again thank you very much for your quick answer!"
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
I have a Singer sewing machine 2638 How do I oil this?
It appears that it calls for an occasional one drop of sewing machine oil (ONLY sewing machine oil) between the bobbin basket (holds the bobbin case) and the hook. There is a photo of it on Page 44 of your user's manual. If you don't have the manual, you can download one free from the Singer Sewing Machine site.
Apr 27, 2015 | Singer Sewing Machines
Oil sewing machine Singer Machine uanhum 5617
contact singer customer service about the machine, some sewing machines you have to oil and some are self oiling, you'll have to ask them which your sewing machine is..
Aug 26, 2013 | Sewing Machines
What are the oiling instruction for a Singer sewing machine, Model # 6250
check with singer and see if the sewing machine is self oiling or
is one that has to be oiled here's their number
1-800-4-SINGER (1-800-474-6437)
Dec 10, 2012 | Sewing Machines
How to oil in singer sewing machine 2808c
some sewing machines are pre oiled some are not, if oiling is not
in the manual then call singer and ask them about oiling
the sewing machine
Oct 23, 2012 | Singer Sewing Machines
Is it safe to use WD40 oil to lubricate my singer 648?
Hi. No, don't use WD40 oil to lubricate your Singer. Use sewing machine oil--it's a whole different breed of animal than WD40 and won't hurt your machine. You can easily find sewing machine oil at Jo-ann's, Hancock's, or any other local fabric and/or craft store. It's not expensive, but repairing the insides of a machine gummed up from WD40 IS!
Good luck and let me know how this works.
Robbie
Jan 11, 2010 | Singer 8280 Mechanical Sewing Machine
Please help..I own a prelude singer sewing
Instructions on oiling your hook (the only area suggested for the user to oil) is located on page 40 of your instruction manual.
Nov 19, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
51 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
