Question about Alpine CDM-7861 CD Player
Troubleshooting on Adjusting Treble/Bass
My Alpine Deck will not let me adjust my settings for bass and treble with my speakers. It allows me to go to the screen but it will not let me adjust the levels when turning the knob. However, the knob works to adjust the volume and subwoofers. Also, the "MX" button on the deck does not work either. Is this a problem with a wire or fuse?
    Novelist:
    Champion:
  • 218 Answers
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
Posted on Aug 10, 2007
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
Dec 25, 2015 | Sony KV-20S20 20" TV
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
Hi there, I have a alpine CDE-9827RR and the bass has stopped working, the MX button now does nothing and i cant adjust the bass or treble settings, I can still see the options to adjust the bass and...
Alpine do have a repair centre if the unit is not old it could be worth you getting them to refurbish it. It will comeback like new if you ask them to go that far. They will quote you first.
Mar 22, 2011 | Alpine CDE9827RR CD Player
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
New car, no manual
There is no straigt forward bass and treble adjustment. You must adjust in either the (x-over) or (users EQ) function. It is a bit tedious but performs the bass and treble adjustments at multiple frequencies.
Aug 24, 2008 | Alpine CDA-9833 CD Player
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
Alpine CDM-7861 CD Player Logo
186 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
