Question about Lenovo ThinkPad R61 PC Notebook
Battery light flashing not charging - Lenovo ThinkPad R61 PC Notebook
I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
not trying to be a smart a** but which of the two do you have?
1. A flashing blue light indicates that the battery is running low on charge.
2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
Best to you.
Feb 20, 2018 | Dyson Vacuums
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2013 | Dell Inspiron 1420 Notebook
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Lenovo ThinkPad R61 PC Notebook Logo
21 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
