Question about Kodak Dock Series 3 Laser Photo Printer
Kodak series 3 printer dock station
The paper was getting jammed and when i got in unstuck the printer will not pull the paper in the machine. its no software problem, its the dock itself. can you tell me how to make the rollers work again to pull the paper in? what should i be looking for?
  • 2 more comments
  • Rosanne0401 Aug 10, 2007
    help
  • Rosanne0401 Aug 16, 2007
    how do i ck for the paper sensor damage? i will try to reload and see what happens.
  • Anonymous Oct 21, 2008
    Cleaned the roller with rubbing alcohol it took paper in and then said jammed. At first it would tell me out of paper.
    Removed paper that was supposed to be jammed & now it does nothing.
  • SS_Camaro_99 Jan 02, 2009
    Every time I try and print with my Series 3 Docking station printer it tells me paper jam on the screen of me C330 Camera that is docked on it.  I pulls the paper in and spits it out the back them tells me there is a paper jam.
    Sergeant:
  • 390 Answers
A very small piece of the paper you pulled out could be lodged somwhere. Very carefully check for this, with a torch! You would be surprised how small a piece can be left behinfd and cause havoc. How do you know it is not a software problem as well. You can have more than one issue amd one can mask the other. Do try reinstalling with pc. Your paper sensor may have been damaged too. This would reult in no paper pulled in, as it cannot sense it is there. Never jam or force paper in as this can also damage the sensor and feeder. You will not know if it is the sensor until you eliminate all else.
Posted on Aug 11, 2007
Paper lodged how do i fix the problem
Posted on Jan 03, 2008
SOURCE:
It keeps saying paper jam why? it is not jammed/
Paper jams are reported under two conditions.
1) Paper reaches a sensor and never leaves it.
2) Paper does not reach the sensor in the time allotted.
A simple test is to put a mark on the next page that should be pulled from the paper tray. If the paper is pulled from the tray, you will find it inside the printer. If the paper fails to feed, it will be sitting in the tray where you marked it.
Don
Dec 12, 2009 | Kodak EasyShare Printer Dock Series 3
Kodak z740 w/series 3 dock station
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=6614&product=EKN029416
AND
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=6639&product=EKN030179
This is the software for you Camera and the printer dock
Oct 04, 2009 | Kodak EasyShare Z740 Digital Camera
My easy share printer dock series 3 is having a paper jam at every photo and only printing half of the photo
please make sure you're using Kodak Xtralife paper - check the back. paper jam and print quality is affected if a different kodak paper is used.
Jul 08, 2009 | Kodak EasyShare One Digital Camera
Kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
May 27, 2009 | Kodak Easyshare Printer G600 Thermo...
Paper Jam / Printer Dock Series 3
try this no promises
unplug the power cord for 5 sec
paper should feed out after resetting
DONT EVER PULL ON THE PAGE WITHOUT THE MACHINE EXITING IT FIRST. THE TABS ON THE END OF THE PAPER BREAKS OFF INSIDE THE PRINTER DOCK.
check the back of the dock for the photo to eject as well as the front.
check paper size with new one after it exits to make sure no extra pieces are stuck in printer. good luck
DONT PULL ON PAGE JAM (UNPLUG FIRST(RESETS THE PAGE OUT THE BACK/FRONT))
Mar 13, 2009 | Kodak EasyShare Printer Dock Series 3
I have a kodak easy share printer dock series 3 and the ink cartridge appears to be locked in. The dock is also not pulling any paper into itself and no jam is apparent.
You have to make sure that the plate on the bottom of the paper tray is springy. take out the paper and fit it in so it is on an angle and it bounces then put the paper in.
Oct 25, 2008 | Office Equipment & Supplies
Kodak easyshare docking station series3
Blow out the printer with blower, there might be dust or some paper piece in the printer
Feb 24, 2008 | Office Equipment & Supplies
Kodak easyshare plus series 3
Easy share printer series 3 won't pull the paper through.
Nov 04, 2007 | Kodak EASYSHARE Plus Series 3 Thermal...
Open Questions:
See all Kodak Dock Series 3 Laser Photo Printer Questions
Kodak Dock Series 3 Laser Photo Printer Logo
114 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
