Question about Integra DTR-9.1 7.1 Channels Receiver
Reset how do i reset the integra dtr 9.1
I am not getting any audio (sound) out of my Integra DTR 4.6. Any suggestions?
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Oct 15, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
It wont turn on
Be sure the power relay has the proper voltage going to it. if so try a reset,if that don't work and all fuses are good you may have a defective micro.
Mar 19, 2014 | Integra Dtr-4.9 Av Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
I am missing the remote for an Integra DTR 5.3 receiver/amp. I have a Sony RM-AV3100 Universal Remote that I want to program to control it. Does anyone know where I can find the 4 digit remote code that...
Hello
Sony RM-AV3100 remote has no codes to setup with any Integra devices. You have to try its code search method. Sometimes you may find a code. But not sure. Go to the user manaul of that remote. There is proceedings for code search process. The codes are four digits indeed. OK.
Oct 09, 2011 | Integra DTR-5.1 Receiver
I have a Integra receiver model number DTR 66 and I have no sound. it appears to have everything connected and should be working. I would like to know how to reset the receiver or what steps do I need to...
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Dec 26, 2010 | Audio Players & Recorders
Power tripped out cannot access video sores when trying toaccess video 1 i am getting dvd sourse
http://www.retrevo.com/support/Integra-DTR-7.2-Receivers-manual/id/550ag003/t/2/
filedepot.onkyousa.com/Files/own_manuals/ADM-2.1.pdf
Below,is the support website for your convince. www.integrahometheater.com/model.cfm?m=DTR-7.1...
I have seen this type of things a few times before in my shop, What has unfortunately happened is that when the power went Off/came back On, it has "Spiked" the Computer Controlling circuitry internally.
Sometimes, if possible, one may be able to "Reset' the unit. But, usually, serious damage has been done. I have given you a link to a manual so you can check.
Jul 20, 2010 | Integra DTR-7.1 Receiver
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
Integra DTR-9.1 7.1 Channels Receiver Logo
Top Integra Audio Players & Recorders Experts
Electro Med Services...
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
