Question about Estate TGDX640JQ Gas Dryer
Whirlpool estate dryer
The dryer is running but it isn't hot and it is taking the clothes a long time to dry.
  • Estate Master
  • 2,254 Answers
On the front panel you'll see a plastic cover that you pop off to see if ignitor is glowing,pop it off and start it,also when it starts do you hear a clicking sound,if no click and ignitor isn't glowing you have a bad thermal fuse,when the fuse blows it's from the dryer running to hot,usually from dryer not being cleaned out or crushed or blocked vent line,unplug the dryer,pull it away from the wall,remove vent line from the back,and remove the back panel,your filter is on top so all your thermostats are in the back,look at the left side you'll see the metal duct your lint filter slides into,to the right and down low you'll see a white piece with two wires,this is the thermal fuse,pull at least one wire off and check it with a meter to see if it's bad,while you're back there,remove the four screws that hold the filter duct on and remove the filter and two phillips screws on the top panel,remove the duct and clean it out,if the vent line is a long run go outside and make sure the hood is open,no covers or screen covering the opening,if clear get a leaf blower,stick it into the vent line from where it connects to dryer and blow out the vent line,put in the new thermal fuse,you should also clean out the front cabinet and you should do this at least once a year so you don't have a fire and your clothes will dry on time,if the fuse is good check the ignitor inside the cabinet,if the ignitor glows but doesn't lite check the sensor and gas coils,when the gas coils are bad usually you'll have a flame liting for like the first 15 to 30 minutes then no flame,when the coils heat up they fail,when they cool you'll have a flame again,go here and see parts
http://www.searspartsdirect.com/partsdirect/part-model/Estate-Parts/Dryer-Parts/Model-TGDX640JQ0/3191/0151200?searchedModel=TGDX640JQ&blt=11
go here to take dryr apart
http://www.youtube.com/watch?v=xGIG8Wo5-N4
if you need anymore help let me know and if you don't have a meter go buy one,it will be cheaper than changing out parts you don't need,set the meter on say 20k ohms,you'll see a number 1,touch the leeds together and you'll see anything but 1,remove at least one wire from the part you're checking,touch the leeds to both sides of the part,if the 1 stays there the part is bad,any other reading the part is good,it's that simple
Posted on May 05, 2013
SOURCE: No heat
What I learned is that the dryer needed a new fuse. The service man took off the back panel to reach any components and replaced the fuse. The dryer now works.
Posted on Feb 08, 2008
SOURCE: estate dryer by whirlpool
does nayone have a pic on where these parts are i have the back removed but im staring at it blankly and i dont want to start ripping parts off (i love to do that though) so anyone with a pic or good explanantion would help thx
Posted on Oct 17, 2008
gotgeek2
  • 565 Answers
SOURCE: Dryer is not drying clothes fully.
As long as the dryer doesn't have electronic controls, this very common symptom indicates a bad(open) heating element.
Posted on Jan 25, 2009
dragonsthatk
  • 547 Answers
SOURCE: Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
yecalam13
  • 41 Answers
SOURCE: Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Posted on Jul 30, 2009
Estate dryer takes too long to dry
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 10, 2012 | Whirlpool Dryers
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
Clothes are real hot to the touch
sounds like you have a venting problem,, check for clogs or blockage in the vent pipe,, and also at the exit from the house to be sure the vent cover flows freely and isn't smashed down. check inside this vent to be sure the flap inside of it moves freely and isn't stuck,, Normally when clothes get hot to the touch its caused by the clothes heating up to dry and the moisture isn't allowed to be vented out
May 24, 2011 | Whirlpool Dryers
Clothes remain wet after multiple times through drying cycle; the "AF" warning lamp is on as well.
AF= Air Flow: there is a restriction; check to make sure that the lint screen is clean,and that the door seal is in place and the vent isn't obstructed, just disconnect the vent and run the dryer, if it clears its the vent tube if not feel the back of the dryer with it running should feel hot/warm air continuous, if not feeling a lot of air, the you will need to take the dryer apart and clean all the lint off. if all checks out good then the control board. Hope this helps Tim
May 22, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Clothes Not Drying well
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Jul 31, 2009 | Whirlpool Dryers
Dryer not drying clothes
An easy way to check dryer function is to check the airflow on the outside of your home at the exhaust the vent. While the dryer is running, and hot, put your hand near the outlet. The air coming out should be hot and forceful. If not, there is most likely an obstruction, and the whole airway should be cleaned. Keeping the airway clean and clear can dry clothes faster and save you money.
Another possibility is the blower,(fan) which can become encrusted with lint, preventing it from moving air. This is much less likely, but still a possibility.
Dec 09, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Dying to slow
hi thanks for the question .I would look at the venting .from the dryer to the outside most problems occur because of poor ventilation dismantle vent and clean thanks the appliance doc
Sep 26, 2008 | Whirlpool LER5636P Electric Dryer
Estate TGDX640JQ Gas Dryer Logo
62 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
