Sharp SC3500AV(GY) Compact Disc Stereo Receiver
I need to know how to adjust the tone arm to prevent skating across a record
madskillz
  • 7 Answers
SOURCE: Tone arm skip back.
You most likely have broken balls,,, lol yes balls bearings are most likely broke you might have to replace your arm.. about 80.00 for the part
Posted on Oct 19, 2007
ctf1800
  • 4402 Answers
SOURCE: Technics 1210 tone arm is really stiff.
sounds more like the grease is hard
Posted on Jan 21, 2008
djproaudio
  • 515 Answers
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
djproaudio
  • 515 Answers
SOURCE: Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Posted on Sep 13, 2008
djproaudio
  • 515 Answers
SOURCE: the stylus skips across the record, despite
If your needle skips across the record, then there is only 1 thing wrong with it... it's broken, and needs to be replaced.
If after you've replaced the stylus, and problem persists, then you have something a little more serious... Tonearm damage. More than likely not, but just in case replace the stylus does not help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Posted on Aug 30, 2009
Why has the part of the arm that holds the balance weight come adrift?
Unit may need a skating adjustment. If the needle still stakes across the record check to make sure the tone arm weight is at least 1.5 grams if good you may need a new stylus or needle. a stylus and a needle are the same thing. Larry
Aug 14, 2015 | Audio Players & Recorders
MAKE MY TONEARM STOP SKATING
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Jan 11, 2008 | Audio Players & Recorders
Denon dp-26F when i tried to play a record the arm just skated all the way across the record. is there a way to adjust the arm so it plays correctly?
The short answer is that you need a new stylus as the one you have is either broken or worn away so that it won't stay in the groove. It could also be out of place. Rubbing your finger on the stylus you should be able to feel it digging in. If you can't it's gone!
Nov 16, 2014 | Denon DP-26F Turntable
Denon DP-297 Turntable Tone Arm Skating
There should be a weight on the end of the arm, this needs to be adjusted. Some have numbers on them, increase the number shown. To get it to work right you will have to do it by trial and error. Increasing the weight in small steps, then playing a record. The trick being so it stays in the groove, but not too much so it rumbles on the sound. You will need to repeat the process several times till it sounds right and stays in the groove.
Jan 10, 2012 | Denon DP-29F Turntable
The record keeps sticking in same place iv adjusted the hight weight and anti skate i know its not the carts or needles cos iv swapped those its been suggested to me tht the arm is damaged or bent even ???
Hi, have you tried manually moving the tonearm (with tt off) from its stating position across the platter to the centre? If you do this and find you get resistance at a certain point then there is damage to the tone arm base or bearings. Is the tonearm lifter going down completely?
Apr 09, 2011 | Technics SL-1200MK2 Turntable
My tone arm has suddenly started skidding across the record surfaces. Its a brand new turntable and was fine till yesterday !!!
Generally the cause is one of 3 things. 1 Damage to the stylus or dirt. 2 Lack of pressure to the stylus. 3 Anti-skate control set to low.
First check the stylus you should feel it sticking in you finger a bit. 2 Has the weight on the end of the arm become lose? Adjust for the correct tracking weight of the cartridge. 3 Check the manual for what the anti-skate control should be set to.
Feb 23, 2011 | Technics SL-1200 Turntable
All the arm does whenever I try to play a record is move across the record. This even happens with a brand new needle. I'm ready to get a new turntable.
there is a counter balance on the side of the arm called an anti skating weight.it prevents the grooves on the record from pushing the stylus inward,wearing out one side.when the anti skate weight system has a fault,it drags the arm toward the center of the record faster than needed.there is also a weight on the back of the arm.that is the balance.when set to zero,the arm should balance.then the weight is turned to 1 gram or so.if there is not enough force downward,the anti skate mechanism will drag the arm inward.
Oct 28, 2010 | Audio Players & Recorders
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Skatinig
You need to adjust the downward force by adjusting the counter weight which is on the back of the tone arm. Rotate it so it's closer to the tone arm fulcrum to increase the weight on the arm, like tightening a nut on a bolt.
Oct 04, 2008 | Numark TT1520 Turntable
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
61 people viewed this question
 Grubhead
Grubhead
