Question about LG Dle5955g Front Load Dryer dle5955g
Lg tromm dryer
Cloths not drying. Cooling indicator stays on at all times
4 Suggested Answers
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
Posted on Jul 04, 2010
KevinWhite
  • 1902 Answers
SOURCE: MY LG TROMM GAS DRYER
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test the fuse for continuity before replacing, if the fuse is fine then please get back to me if you have any other questions.
Kevin
Posted on Apr 11, 2011
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
May 20, 2010 | LG DLG5932W Gas Dryer
Lg tromm dryer electric cooling light staying on
I started researching on here because I was having the same problems with my LG dryer. (It also happens to be the same model.) I discovered the vent hose was kinked.
With the lights, the cycle it's on that blinks. When your dryer gets to the last 5 minutes, the "Cooling" light will blink and the "Drying" light will go off. If you have the "Wrinkle" setting on after the 5 minute cooling cycle, the wrinkle cycle will start and circular lights will show where the minutes normally are displayed and the Wrinkle light will blink.
Dec 02, 2009 | LG DLE2514 Electric Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm dryer now takes two cycles to dry a load
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
Dec 20, 2007 | Dryers
LG Dle5955g Front Load Dryer dle5955g Logo
27 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
