Question about JVC HD-52G787 52" Projection Television
JVC HD-56FN97 Color Issue
My JVC HD-56FN97 turns on, isn't very bright, and the colors are all wrong. Everything is in a shade of green or purple. What is wrong? Lamp was replaced and nothing changed.
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
SOURCE: JVC 56FN97
Make sure the bulb is seated properly in it's hole. It has to be an exact fit or it won't work.
Posted on Oct 16, 2008
ladywinn
  • 5138 Answers
SOURCE: JVC 56" projection tv
Replace STKs in convergence board.
Posted on Nov 27, 2008
SOURCE: Green Shade on tv screen
This is a typical example of a convergence amplifier failing (any brand would be the same).
More than likely there are 3 amps and they should all be replaced together. Parts shouldn't be too
expensive but I would expect approx $100 US in North America and about £100 UK. Bear in mind thats for the repair not any transportation costs to/from the repair centre.
SD Tech
  • 14553 Answers
SOURCE: My JVC HD56 has a purple/green tint and isn't very bright.
Not worth attempting to fix and that is the reason it was tossed.
Posted on Apr 01, 2012
What causes the purple area in the middle left quadrant of my screen?
It's an impact point, something has come into contact there
May 22, 2016 | JVC HD-56FN97 56" Television
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
JVC HD 56FN97 No RED color
Does menu have any red? Yes = digital video bad; No is light engine bad.
Mar 31, 2014 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
JVC HD-56FN97 all blue colored objects are green; blue water, clothes etc. what is the problem?
Check with JVC as at least on one of these sets had these issues: wrong color, any color missing, picture upside down or backwards lettering etc and this one required the use of the computer with a jig from JVC to download to the unit itself two files.
It sounds like a firmware/software issue and if so JVC should have it on record.
I remember as we were authorized and were at first informed they would charge us three hundred for even using the jig---our owner simply said fine, we will tell the customer we will have nothing to do with this repair(nearest other service center was 150 miles, they had to give us the unit for free or end up replacing the set. My point is they are not the easiest people to deal with unless you have the upper hand with them.
Dec 11, 2012 | JVC HD-56FN97 56" Television
My JVC HD-56G787 television has lost all blue color, everything is now green and purple.
Yes, contact a local JVC authorized repair shop--if I remember this model correctly it had this issue: missing a color or wrong color, picture backwards or even upside down.
What was involved at the time was connection of the set to a computer and two files downloaded from their site---there is a multi-pin plug inside the rear of the set (have to remove cover) that when the process is done will reset the processor in the set to correct any or all of the above issues.
The process requires the jig JVC designed for this and hence you want a JVC dealer. When we did them they provided the jig/
Jun 12, 2012 | JVC HD-56G787 Television
Apr 01, 2012 | JVC HD-56FN97 56" Television
I have a JVC Model HD56FN97 (bought in 2007). I replaced the lamp, and now I have a pinkish circle on part of the picture. Any solutions?
Possibly a color wheel issue - do you here a constant wining noise..if not its likely the light engine issue
Mar 21, 2012 | JVC HD-56FN97 56" Television
We have a JVC LT-32JM30 and recently for no reason at all, the picture color has messed up, we have tried resetting and adjusting the tinit, etc but nothing works. Everything is a varying shade of green or...
an internal degaussing coil circuit is already installed in the unit to neutralized color pattern...a loose solder connection may have caused this because as it operates temperature increases between the thermistor..
Jul 15, 2011 | JVC AV-27530 27" TV
Poor quality picture. specifically the red is brown and can't be adjusted. the tv is about 3 years old.
If the picture is replace the lamp. Lamp only affects brightness if the color is wacked replace the light engine.
Mar 26, 2010 | JVC HD-56FN97 56" Television
JVC AV_48WP30 Screen loses color, everything is in like negative color
Sounds like shading, caused by convergence IC or bad solder connections in convergence circuit. Check the CONVERGENCE GALLERY for shading.
JVC design is generally reliable. It is extremely unlikely that you would have 2 unrelated failures.
If you are in Canada, email me.
easyab
Oct 27, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC HD-52G787 52" Projection Television Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
