Question about Brother XL-5130 Mechanical Sewing Machine
Help I have no idea what is wrong.
Every time I press the pedal, the needle doesn't go down. If I try to turn the wheel on the side it won't move therefore the needle doesn't move either. I have recently oiled it so that isn't the problem. Please help I have no idea what is wrong.
I think this is lint build up. Try dissasembling the bobbin case parts any other parts on the bottom of the machine that could be collecting lint.
Posted on Aug 25, 2007
SOURCE:
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Sewing needle won't move
it could be a part is damaged or broken or a timing problem,,it
would be a good idea to have the machine checked.
Dec 09, 2012 | Sewing Machines
Needle and take-up lever don't move when I push the pedal
It's possible there's a part loose or broken only a sewing machine repair shop can tell what's wrong
Feb 02, 2012 | Singer Sewing Machines
Brother sewing machines lx2500
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster i need help to :{
Nov 25, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a babylock 1556 and when I press the foot petal the belt turns, but it won't move the needle up and down. I took off the back so I could watch and see what was going on. I can see the belt...
On the side of the 'knob', look for another wheel that tightens against that, so it engages, that's what it sounds like. When that second wheel is loose, it won't run, it just spins. From the photo I can find of the unit, it looks like that second wheel is below it, but I can't be certain. Let me know how you make out. Please rate and comment, thank you,
Joe
Sep 04, 2011 | Baby Lock BL1556
I have a singer 6106 but no manual. When I press the foot the needle doesn't move although the outer wheel on the right hand side of the machine goes round. If I move the inner wheel on the right the...
go to http://www.singerco.com/accessories/instruction-manuals and type in your model number, then click "search" to locate the manual for this machine.
Sounds like the clutch is disengaged on your flywheel. Hold the outside of it and turn the inside bit away from you to reengage it.
May 28, 2011 | Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Brother XL-5130 Mechanical Sewing Machine Logo
65 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
