Question about Vtech Sit To Stand Learning Walker
How to remove the parts? - Vtech Sit To Stand Learning Walker
How to repair lighter
Hi jewel,your lighter has 3 parts,fuse in fuse box,always check this first,if good then second part to check is the lighter itself,if you can,remove and try in another vehicles lighter outlet.If it works then lighter outlet at dash is bad,try another lighter in your outlet.You can buy new parts at Autozone,if you need to remove part from dash,remove fuse,there\'s a clip on other side of lighter at dash,you will have to remove clip to remove lighter part.Cut wire,but leave yourself plenty to tie in new lighter,use blue butt connectors and a crimp tool.
Jan 20, 2013 | 2000 Ford Mustang
Removing back seat cutlast 1999
CARFULY LOOK AT ALL ATHACHMENTS -DISASEMBLE -REMOVE
Aug 08, 2012 | Chevrolet Cars & Trucks
How is the agitator removed for cleaning collected lint?
Hi, W/D here.
Remove the dispenser cup. Remove the cap below it. Then remove the bolt and washer. The agitator will lift out. Here's a link to a parts list and diagram that you can follow to help you:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/Model-FWSB5700DS0/1428/0153200/R0402083/00002?blt=06&prst=&shdMod=
Best regards, --W/D-- Please feel free to rate this solution. Thanks.
Feb 18, 2011 | Frigidaire FWSB5700DS Top Load Washer
How to remove the starter clutch housing (Original part number is 212131 in the Illustrated Parts List online at briggsandstratton.com.) from the vertical crankshaft of a Briggs and Stratton engine, Model...
Brace the mower blade against the housing of the mower with a block of wood, so that the blade cannot turn.
Using a Strapwrench, a chainwrench, or a pipewrench, secure the lowet part of the starter clutch assembly in the wernch and turn it counter clockwise, looking down at the top of the engine.
Aug 12, 2010 | Briggs & Stratton Garden
Need to replace the headlight bulb. Removed the
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Seeing an exploded view may help answer the question.
Aug 04, 2009 | 1996 Honda VF 750 C Magna
How do I replace the windshield washer nozzle on the 2003 Saturn Vue? I went to the dealer and purchased part number 22722205 but need to know how to remove the broken part and install the new part.
Open Hood,Remove 4 push pin retainers,remove wiper arms.If it's the pass side you will not need to remove wiper arms.Driver's will need arms removed
Apr 23, 2009 | 2003 Saturn VUE
1999 nissan quest rear brake shoes need changing
help is here:
http://autos.groups.yahoo.com/group/villagerquest/
Drum Removal
  1. Remove the rear wheel and the tire assembly. Refer to Section 204-04 .
  1. Retract the brake shoes and loosen the brake adjuster screw.
  1. Remove the brake drum.
May require big hammer to loosen drum from axle flange. Hit between the the lugs, not on them.
#10 is access plug to back off adjusting wheel.
Item Part Number Description 1 2261 Rear wheel cylinder 2 — Dust boot (part of 2128) 3 2197 Wheel cylinder piston (part of 2261) 4 — Cup (part of 2128) 5 2204 Wheel cylinder piston cup spring (part of 2128) 6 — Wheel cylinder housing (part of 2261) 7 — Brake shoe hold-down pin 8 — Access hole (part of 2212) 9 — Rear brake bleeder screw (part of 2261) 10 — Access hole plug 11 — Rear wheel cylinder bolt 12 2212 Rear brake backing plate 13 — Rear brake backing plate bolts 14 2N790 Parking brake lever clip 15 — Spring washer 16 — Secondary brake shoe and lining (part of 2200) 17 — Brake shoe hold-down spring (part of 2B514) 18 — Lower retracting spring (part of 2B514) 19 2A637 Parking brake lever 20 — Parking brake lever pin 21 2A177 Brake shoe adjusting lever 22 — Adjuster lever pin (part of 2A177) 23 — Primary brake shoe and lining (part of 2200) 24 — Upper retracting spring (part of 2B514) 25 2041 Brake adjuster screw
Shoes Removal
Take a picture and remember how each part goes and attaches
  1. Remove the brake drum, refer to Drum in this section.
  1. Remove the upper retracting spring.
  1. Remove the lower retracting spring.
  1. Remove the self-adjuster.
  1. Remove the hold-down springs.
  1. Remove the parking brake lever clip and the parking brake lever.
Apr 17, 2009 | 1999 Nissan Quest
I need to replace the CMOS battery in a Presario 906US Laptop
Here is service manual for Compaq Presario 900 (download parts one by one, then extract):
Part 1
Part 2
Part 3
Part 4
Mar 28, 2009 | HP Compaq Presario 906US Notebook
Window winder handle
the window winder consists of two parts - the handle part and the round part. if you look at the round part, you will see that it consists of two parts. the bottom part can in actual fact be pushed forward (this is the part closest to the door panel). if you push this forward it will un click and you can remove it.
hope this helps
lizanne
Jul 06, 2008 | 1996 Volkswagen Golf
Vtech Sit To Stand Learning Walker Logo
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
