Question about Nakamichi Soundspace 3 Shelf System
The cd door keeps opening and closing - Nakamichi Soundspace 3 Shelf System
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer ยท CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
? 9:21
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
My Emerson MS3108 door keeps randomly opening. All CD music stops when it opens and it opens within seconds of the previous openings. Is there something I can do?
It is a leaf switch that senses that the door is closed. A C-clamp in the upper left hand corner clamping the door closed will make it work. If you remove the clamp, it will randomly open again. The correct fix is to open up the unit and bend the leaf switch to make it activate earlier and fully close when the door is closed.
Nov 14, 2009 | Emerson MS3108 Shelf System
Denon CD player DCD 920. When using the open/close button once, the CD-door opens but when it is open, without any waiting time, it immediately closes again. If i operate manually the open/close switch on...
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Oct 14, 2009 | Denon Audio Players & Recorders
Cd door wont shut
this is possible but can lead to more frustration. The cd door usually has a plastic tab that depresses on a button or blocks the opto sensor to indicate it is closed. I presume that your cd door is missing this tab or the circuit that activates when the door is closed is faulty. Block the opto sensor manually using paper or keep the button depressed that the door tabe closes on. You will not need anything to keep door closed unless it is reqiured to play the cd then just use a brick
Aug 15, 2009 | GPX Karaoke Party Machine CD+G Portable...
Dvd/cd drive door keeps opening and closing by itself
If the trouble isn't being caused by some screwy virus or software problem, the best solution is to replace the drive. New drives are quite inexpensive and widely available in retail stores (at higher prices) and online.
May 27, 2009 | HP (D4384-63002) (d438463002) Internal 32x...
Driver door keeps opening and closing
Could be virus infection install update to your antivirus or better check free antivirus.
Leave a comment, tnx
Apr 08, 2009 | E-Machines emachines (emachinees) CD-ROM...
Cd/dvd door is opening and closeing all by it self
this is due to improper connection of wire from optical drive to motherboard i.e check whether the power cable/ide(sata)cable is not loose.Also clean their plugging area.problem will be solved.thanks.
Nov 23, 2008 | HP Pavilion a6544f Desktop PC
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
Cd door keeps onpening and closing
When this happens it is usually one thing, but could be two.
The most common reason is that the button you use to open and close is stuck in the IN position. Turn the PC off with the drive door held open. Using a paperclip try to get behind the push button and press it outwards.
Second most common problem, the switch the button activates is worn and has failed in the depressed position.
Fortunately, replacement CDROM/DVDROM are rather inexpensive, but you would need a technically savy friend or relative to help you or you can ask your friendly neighborhood computer guru to help. Or, lastly, you can take this into a shop for a replacement as the newer drive will be better and faster than what you have now.
As always, if you have any need for clarification or further questions please do not hesitate to comment back to me.
Regards,
Worldvet
May 25, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Nakamichi Soundspace 3 Shelf System Logo
49 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
