Question about Refrigerators
Maytag MBF1958WEW1 Refrigerator not getting cold, freezer is fine
HVACRH20
  • 237 Answers
SOURCE: refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Posted on Jan 06, 2007
  • 159 Answers
SOURCE: Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Posted on Aug 06, 2007
SOURCE: maytag plus refrigetor not cooling model msd2756geb
after removing all of the freezer racks and shelf pull the 4 1/4 inch screws out at the bottom back panel of the freezer. pull the 2 panels off and slide them out strait down to the floor of the freezer. if your freezer coils are full of snow and ice then the fan cant pull any cold air up into the refrigerator.your problem is probably th defrost adaptive timer. if the heater ohms out at around 20 to 30 ohms it is ok. next ohm the 2 white wires at the plug this is checking the thermostat it shoud ohm out at aproximately 240 k ohms if those 2 things check out the problem is the adaptive defrost timer it is in the ceiling behind the temperature controls on yhe right side.
Posted on Aug 05, 2009
  • 4 Answers
SOURCE: Refrigerator side doesn't feel cool but the
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Posted on Jul 23, 2010
aasc
  • 1606 Answers
SOURCE: Side by side Maytag refrigertor that is not
Due to only lower cooling of the refrig , this sounds like the freezer fan which circulates the cold air into the refrig , has stopped working . This will be one of two things . Freezer fan not working or defrost problem . Open the freezer door and listen for the fan . If you do not hear the fan , remove the inside freezer panel ( lower ) by removing the 2 screws . If the fan is not working , replace the fan motor . If the coils are coated with thick frost , you will need to check the defrost system . Unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Posted on Aug 01, 2010
Maytag bottom freezer upper fridge fridge stopped getting cold freezer is fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
My Maytag Plus side-by-side refrigerator model # MZD2766GES is not keeping anything cold. The freezer side seems to be working just fine.
heatman101
May 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
Maytag MFD2560HEW refrigerator. Refrigeration section not cooling... Freezer appears to be fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 15, 2011 | Maytag MFD2560HES Bottom Freezer French...
My refrigerator is not staying cold...this just started to happen yesterday...it is warm today? The freezer is working fine? Help
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Dec 24, 2010 | Maytag MFD2561HE Bottom Freezer French...
The fridge is not cold but freezer is working fine
heatman101
Nov 26, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
My refrigerator has stopped cooling - though my freezer is still cooling just fine. Please help!! Model # is Maytag MFD2561KES
heatman101
Nov 01, 2010 | Maytag MFD2561KES Stainless Steel Bottom...
Clicking sound
Of course it is a loose connection. But don't try to fix it your own. You are well inside the warranty period. You can complaint about it to your dealer who will provide you free assistance.
Apr 20, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerator not working, freezer is fine
You can get the step by step instructions (lots of pictures of each step) to repair this exact problem at:
www.AnyoneCanFixIt.com (specifically at http://www.anyonecanfixit.com/household.htm scroll down towards the bottom to look for Warm Refrigerator and Cold Freezer repair). It will save you a lot of money to do it yourself!
May 17, 2009 | Maytag MFD2560HE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
