Question about Motorola Mobility RAZR V3c Cellular Phone
When i turn my phone ON and i press any button it goes off
My phone goes off anytime i press a button and it want keep a charge
  • 29 Answers
If the phone won't hold a charge, try changing a charger or a battery. if still won't do any difference, check your local service center.
Posted on Oct 01, 2007
SOURCE:
The apple comes up then goes off
In most cases, you can solve these problems by putting the phone into recovery mode and restoring it from backup. To do that, follow these instructions:
  1. Connect the iPhone's USB cable to your computer, but not your iPhone.
  2. Turn your iPhone off. If the phone won't turn off in the traditional manner, just keep holding the buttons until the screen goes dark.
  3. Once you've turned the device off, press the home button on the face of the device and plug in the USB cable to the device's dock connector.
  4. When it turns on, keep pressing the home button until the iTunes logo appears on the screen.
  5. You'll know the phone is now in recovery mode because a window in iTunes will tell you.
  6. You can then start the restore process by clicking the "Restore" button in the iTunes window.
Apr 16, 2014 | Apple iPhone 4S
Micromax a90
Hi, try these. press power and volume down button for 10 sec. Then try to power up it by briefly pressing power button. if fails, press power and volume up, be carefull , when the screen comes live - not to select any other option but only normal boot. To select a option press volume up button, it will power off, then power on again by pressing power button. it may fail by keep trying and in between keep charging ..
Thanks
Jan 16, 2014 | Android Cell Phones
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
There are 3 signs on my cell while charging.
firmware issue. kindly download 3.1.2 firmware and and jail break it using blackrain.
to download firmware visit www.redmondpie.com for blackrain : www.blackra1n.com
use itunes to update the phone to select the firmware keep pressing SHIFT button n then press restore n browse n select the firmware file.
Feb 28, 2010 | Apple iPhone Smartphone
My iphone charges but won't turn on
I see this problem usually with haxed iphones, is yours haxed? Try plugging it into your computer, does your cpu recognize it and load itunes? even if it still shows the red battery. If you cant get itunes to recognize it then do a restore and this should fix the problem. If the above does not work you can try and press the power button for 5sec keep holding it and then plug it in to a power source, keep holding the button for another 5sec after and see what happens. If all else fails it may be time for a hard reset, if you dont know how, press and hold the menu button and the power button till you hear a beep, then let go of the power button and keep holding the menu button till you hear a second beep. Cali
Jul 25, 2009 | Apple iPhone Smartphone
Blank white screen
Make sure the phone is charged.
Press the Home button and the power button at the same time for about 10 seconds then release both, now press the power button briefly, the phone should start.
Let me know how it goes.
Jan 13, 2009 | Apple iPhone Smartphone
My phone doesn't want to turn on!
First make sure your phone is fully charged. Then check...
It may be the storage card - if you take the storage card out it will boot up and you can put it back in. - pain in the a## but it may work. Or Try taking the SIM card out, boot it up, turn it off, replace the card, and turn it on again.
Last resort is a hard reboot. If you did a hard reboot and nothing happened then you did not do it successfully. To do a hard reboot.
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
- if you dont see the black screen with the reset option, pull the battery out, reinsert it and repeat the above steps
- when you see the black screen with the reset option, press the Send button to confirm the reset.
Nov 04, 2008 | T-Mobile Dash Smartphone
Nokia N70 will not turn on
Actually when you want to switch on your phone, but it's not turned on,but when you charge the phone, the battery indicator goes up, it just mean one thing : YOUR ON-OFF SWITCH is broken!!
so how to replace this on off button? well, if you can, open the casing of your phone. you'll see the real on-off switch below the usual on-off button we have on the casing. press it. Good luck ^^
Btw if you have no luck pressing the real on-off switch, replace it, bring it to technician. It shouldn't cost you more than 10usd if you told them to problem (if you didn't tell them, they'll say, oh your IC got broken, oh your phone will cost much on the fixing, oh this oh that, they'll **** your money..). Just said, hey, my on-off switch got broken, please fix it.
You can get my head cut-off if I' wrong.. haha, I'm pretty sure that's the problem.. well there's a little case of broken circuit that might cost you much more, but shouldn't be more than 20usd too ^^ Good luck
Mar 07, 2008 | Nokia N70 Cellular Phone
Phone won't turn on
You may need a new battery. Also, hold the power button in for at least 10 seconds before letting go. The RAZR has a bad habit of not completely turning on unless you hold it in long enough.
Nov 30, 2007 | Motorola Mobility RAZR V3
Phone frozen n keeps shutting on & off
sounds like you got a real prob.
try a different batt if it still does the same then I would be looking for the shop reciept and seeing if it was still under warranty because those are classic symptoms of liquid damage.
Nov 03, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
