Question about Shimano 09 Xtr M971lc Mountain Bike Rear Derailleur
Shimano st m020 - Shimano 09 Xtr M971lc Mountain Bike Rear Derailleur
Exploded view of shimano gear shifter altus st-ct90
Sorry, Shimano never intended those shifters to be taken apart and serviced, so they didn't release an exploded view. Here's a link to the orginial EV document. http://bernd.sluka.de/Fahrrad/Shimano/TM/ST-CT90_1995.gif
Mar 30, 2017 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Hi! is there any replacement for shimano ST-3300, 8 speed, right hand STI lever?? many thanks
There's a used pair on an eBay auction right now ending 6d 09h (Sep 21, 201101:52:54 PDT) that you might be able to snag for cheaper than a separate right lever. Wait til the last 10 seconds and bid ONCE. Leave time to confrm the bid.
http://www.ebay.com/itm/SHIMANO-SORA-8-SPEED-STI-3300-BRAKE-LEVERS-DUAL-SHIFTERS-8x2-8sp-/200651614761?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2eb7c4aa29
There are other models, too.
My $.02: I'd take the opportunity to switch to Campi Ergo (also available on eBay). The brake lever is ONLY a brake lever so you don't have to tip toe around it when shifting and ALL CABLES are hidden.
Sep 14, 2011 | Shimano Sora ST-3304
Need advice for Shimano ST-7900 nameplate replacement
Don't know if you have an exploded view diagram of the levers . If not you can download from http://techdocs.shimano.com/techdocs/index.jsp
In the road bike drop down list select Dura-Ace, go down to ST-7900 and select document EV-ST-7900-2874. I don't advise you to take mech apart unless you have special tools and bags of experience handling complex mechs. However you will see that name plates are held by single screw which should be no problem.
Nov 19, 2009 | Shimano Cycling
How to dismantle and re-assemble the lever mechanisms as the levers are slipping when operated. Hopefully they are not worn internally. They are Shimano ST-T400 shifter/brake.
Here's the diagram:http://fish.shimano-eu.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-T400-S-1970_v1_m56577569830613258.pdf The lube in them tends to dry out and harden over time and needs to be flushed out with whatever is safe for the parts (cleaner/degreaser) and then relubed with some high quality lubricant. The spray stuff doesn't stay around long enough. Ask your local bike tech what he uses.I used saxophone key oil.
Aug 08, 2009 | Cycling
Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Shimano 09  Xtr M971lc Mountain Bike Rear Derailleur Logo
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
