Question about Elna 2007 Mechanical Sewing Machine
Will the Elna walking foot fit my Elna 8000 machine purchased in 1992?
  • 11 Answers
SOURCE: Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Posted on Oct 28, 2008
sonicboomele
  • 1557 Answers
SOURCE: broken walking foot
there are many companys on the net that sell secound hand electronics parts like car wreckers google secound hand elna parts good luck
Posted on Apr 20, 2010
Tally Girl
  • 1133 Answers
SOURCE: I purchased an Elna 7000
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Posted on Mar 27, 2011
Tally Girl
  • 1133 Answers
SOURCE: What make of walking foot
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
Posted on Jun 25, 2011
SOURCE: walking foot for 1963-1964 elna supermatic
try a elna dealer
sew4less.com
Posted on May 16, 2012
Walking foot for ELNA 9000 or Elna lotus zz please
SORRY FIXYA does not sell any products , check with a sewing machine company
Aug 17, 2017 | Elna Sewing Machines
I have an Elna 8000 sewing machine and need a walking foot for it and can't seem to find one
Unfortunately the walking foot for that machine was discontinued some time ago. Sometimes a roller foot will serve the same purpose for much less money. That is what I would try.
Oct 17, 2014 | Sewing Machines
Walking foot for 1963-1964 elna supermatic
try a elna dealer
sew4less.com
May 15, 2012 | Elna Sewing Machines
What make of walking foot would fit my Elna su air electronic sewing machine, thankyou
Jun 25, 2011 | Elna 2007 Mechanical Sewing Machine
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
Trust this helps.
Mar 24, 2011 | Elna 8007
I need a new foot for my old elna, where can I purchase one. Elna SP purchased around 1971 --1972 from White Sewing Center , Cocoa Fla I live in Mount Holly N.C. 28120
you can buy Elna parts from www.whitesewingcenter.com, he specialises in the Swiss Elnas and carries range of stock. Or www.sewingpartsonline.com or www.sewusa.com stock Elna parts for both early Swiss as well as the latet ones. not sure if you meant a pressure foot or the foot control. If its pressure feet the generic low shank feet may well fit your mschine too once you buy the pressure foot adaptor for the newer clip on feet. There was a Lotus Sp and a star SP but the pressure feet were the same with the built in shank you attached with a thumb screw. the air electronics had the adaptor and clip on feet but they have same height and needle position so can use on earlier ones too.
Oct 01, 2010 | Elna 2007 Mechanical Sewing Machine
Broken walking foot
Apr 20, 2010 | Elna 1010
Elna walking foot
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Elna 2007 Mechanical Sewing Machine Logo
95 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
