Question about MSI Custom 845 Ultra-c Ver:1 Motherboard 2.4ghz 512mb 80gb Linux Mint 12 Loaded
Power supply my 420 watt switching power supply quit working and I need to replace it.I need to know what the max wattage power supply the msi ultra-c ver.1 motherboard will accept
    New Friend:
  • 4 Answers
Any 450 Watt SMPS power supply is ok. Zebronic or Mercury retails around Rs.450 to 500. No need of costlier power supply like Corsair etc.
Posted on Jul 06, 2013
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
Alienware aurora desktop with 525 Watt Power Supply was working fine then all of sudden started making a loud noise like it was going into overdrive or something then emitted a horrible like burning...
The switch mode power supply in the desktop computer has failed. Most likely the capacitors in the power has exploded.
You need to open the desktop computer and remove the old power supply and replace it with a new one. Take the old power supply with you to your friendly computer shop and get a replacement power supply with the same wattage or greater wattage.
Jul 25, 2010 | Alienware PC Systems Alienware True 480...
No bios on kt4 ultra
You will need to contact MSI for a replacement updated bios; http://us.msi.com/index.php?func=service
Mike
Jun 07, 2010 | MSI KT4 Ultra (MS-6590-010) Motherboard
N15232 motherboard wattage help
the power supply wattage rating is MAX wattage, not constant wattage. the power supply only outputs the amount of power that the rest of the computer calls for, and no more. if yor computer only needs 200 watts, that is all that will be sent from the power supply; even if it has a max rating of 600 watts, it will only send the amount of watts which your computer calls for.
May 08, 2010 | Computers & Internet
Need to upgrade Alienware PC with P5GD1-VM
You need 24 connection power supply 500 watt
Apr 29, 2010 | ASUS P5GD1-VM Motherboard
My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Jan 04, 2010 | Dell XPS 420 PC Desktop
Manual motherboard msi (ms-6547) ver 2
There are 5 versions of this model
http://global.msi.com.tw/index.php?...
They have either 5 or 6 PCI slots.
Find the version number - beside the model number
Note the SiS main chipset numbers (one may be under a heatsink)
MS-6547 Ver 1.0 a.k.a. 645 Ultra - ATX, 5 PCI slots
SIS® 645 Open Architecture DDR333 Chipset
SIS® 961 MuTIOL® Media I/O Chipset
MS-6547 Ver 2.1 a.k.a. 645 Ultra-C - ATX, 6 PCI slots
SIS® 961B MuTIOL® Media I/O Chipset
MS-6547 Ver 2.0 a.k.a. 645E Max - ATX, 6 PCI slots
SIS® 645DX Chipset (under heatsink)
SIS® 961B Chipset
MS-6547E Ver 1.0 a.k.a. 645E Max-C - ATX, 5 PCI slots
SIS® 645DX Chipset
SIS® 961B Chipset
MS-6547 Ver 2.2 (2.1) a.k.a. 645E Max-U - ATX, 6 PCI slots
SIS® 962L Chipset
Jun 27, 2009 | MSI MS-6547 Motherboard
Can i put a 9800 gtx+ on a dg31pr motherboard?
OK, Here you are . Your present card ,8500GTdraws approximately 40 watts. Your proposed card draws approximately 150 watts according to a review I just read on it.  A 400 watt is not very much and if you get close to maxing out you run the risk of a low voltage problem which could and will burn out compoinents.  I would not do it.    Also , if you upgrade power supply, know that the wattage given is usually peak , not operating wattage which can be as much as 10 or more percent less. Go for at least 600.
Feb 17, 2009 | Intel DG31PR Motherboard
CPU Fan
Hello rc53_61,
If you look at the back of your old power supply you should be able to find the information you need (if you are going to replace the current power supply with the same one). The best place to find an exact power supply is visiting the manufacturer of your computer system for example: dell, hp, compaq, etc. You can replace a power supply rather easily, the only things you need to make sure is that the plug connection is compatible with the one on your motherboard and the power supply rating is the same or even a bit higher for wattage. Check the following links to find some good quality power supplies at a reasonable rate. These sites will help you with compatibility also by putting in your motherboard information. Let me know if you need further assistance.
Tiger direct
Directron
Just in case the links do not work properly
http://www.directron.com
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Sep 06, 2008 | MSI KT4 Ultra (MS-6590-010) Motherboard
Issue with a In Shin Power Supply
ok, the part # is not the model # . I need the MODEL # of the board to help U .
Dec 30, 2007 | Computers & Internet
MSI Custom 845 Ultra-c Ver:1 Motherboard 2.4ghz 512mb 80gb Linux Mint 12 Loaded Logo
93 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
