Question about Intel Computers & Internet
Intel Raid Card axxrmsll040 configure problem
Unable to get into configuration mode with axxrmsll040 raid controller installed on intel S1200BTLR mb. Won't respond to CTRL-C. Won't respond F2 to get into regular setup if the raid card is installed. If I remove the raid card, i can get into F2 but alas, have no RAID card. Thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
Need to download driver for raid driver https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Server%20Board%20s1200bt%20Family
Posted on May 21, 2014
DRSS
  • 81 Answers
SOURCE: Raid JMB363 RAID BIOS UTILITY
The P5K motherboard has a four port vanilla ICH9. There
Is no RAID on the Intel, when the chip has only four ports?
So S1, S2, S3, S4 are not RAID.
In the P5K manual, the RAID function exists on the Jmicron
Controller. One drive connector is internal (SATA_E2, on the
Left of the motherboard picture in the manual), and one
Drive connector is external (F_ESATA on the back I/O area).
This is not convenient for building a RAID0. (The intent is
To allow making RAID1 backup disks.) You'll have to snake
The SATA cable back into the computer, if you hope to use
It with two internal SATA disks.
The manual has full instructions for setting up RAID on the
Jmicron JMB363. The manual says to set the Jmicron to RAID
Mode in the BIOS. Two disks must be connected, in order to
Be able to press <control-J> at the start of the BIOS, to
Enter the Jmicron RAID setup in the BIOS. At that point, you
Can declare an array in the BIOS setup.
Then, when Windows is installing from the Microsoft install CD,
You’ll need to press F6 and offer the Jmicron RAID driver.
Section 5.5 of the Asus manual, describes how to make
A RAID driver floppy. The application in the mother board cd is available for make drivers disk
Posted on Dec 10, 2007
map9966
  • 2351 Answers
SOURCE: raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Posted on Jun 13, 2008
SOURCE: Hard drives and RAID
rock01
Posted on Oct 27, 2008
gotgeek2
  • 565 Answers
SOURCE: SATA RAID Controller Card Problem?
You are almost there. Go into your BIOS and enable RAID. Then your raid bios should show up on next boot.
Posted on Feb 15, 2009
  • 13 Answers
SOURCE: XP is Not Recognizing Sata H.D. and I Need a RAID Controller Driver
This one should be right for you, remember to put it on a floppy, since XP needs a floppy for a 3rd party driver during install.. good luck!
http://download1.msi.com/files/downloads/dvr_exe/sis_sataraid_floppy_mb.zip
Posted on Jun 02, 2009
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
What is intel(R) matrix storage manager
Yes you need it. document.write("The files below contain the Intel® Matrix Storage Manager.
This driver provides support for high-capacity & fault-tolerant Serial ATA (SATA) RAID 5 arrays and high-performance & fault-tolerant SATA RAID 10 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X and 945 chipset-based platforms. It provides support for high-performance SATA RAID 0 arrays & redundant SATA RAID 1 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925, 915 chipset-based platforms. It also provides AHCI support on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925 and 915 chipset-based platforms, as well as on Mobile Intel® 915/910 chipset-based platforms.
Note: Intel® RAID Technology requires the Intel® ICH9R/ICH9M-E/ICH10R/PCH/PCHM SATA RAID controller hub, Intel® 82801HR I/O controller hub (ICH8R), Intel® 631xESB/632xESB I/O controller hub, Intel® 82801GR/GH I/O controller hub (ICH7R/DH), Intel® 82801FR I/O controller hub (ICH6R).
DISCLAIMER: This software is provided by Intel only for the convenience of its customers. THIS SOFTWARE IS PROVIDED \"AS IS\" WITH NO WARRANTIES WHATSOEVER, INCLUDING ANY WARRANTY OF MERCHANTABILITY, NON-INFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, OR ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. This software is furnished under license and may only be used or copied in accordance with the terms of the license. The software is subject to change without notice. Intel assumes no responsibility or liability for any errors, incompatibility issues, inoperability or inaccuracies that may appear in this software.
See the Installation Instructions page for a list of system requirements and considerations.
Note: Before installing this application or requesting technical support from Intel, it is suggested that you first contact your system manufacturer. They may provide software which is specifically configured for your system.")The Intel® Matrix Storage Manager.
So don't delete it.
Mar 10, 2010 | Computers & Internet
I got a Dell Precision 690 in which I have 2 SAS hard drives of 300gb and OS is XP 64Bit.This Disks are connected in HD0& HD1. When I tried ti reinstall XP 64, setup load the file and when start the...
if your hard drives were in a RAID configuration at any point or your computer has a RAID controller in it nothing will work until you reconfigure the RAID setup. it is probably a good idea at this point to completely wipe the drives as there may be some lingering RAID configuration data remnants on them and this can also mess things up pretty good.
Feb 25, 2010 | Dell Precision Workstation 690 - 750W...
I can not set up window xp on mainboard intel D845PEBT2, Because it has raid. and i don't know how to configure raid to setup window. so do you have any solutions for me?
To solve this problem, go to your computer BIOS by pressing the delete key repeatedly in the keyboard while on start-up. Once you enter the bios utility, go to advance settings and turn the "SATA mode" to "IDE" not "RAID". Refer also to the motheboard manual to do this.
Oct 31, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Convert to raid 1 after Vista install
Install at least 2 more hard-drives, and configure them to use RAID.
Then, copy/move all your data-files from "My Documents" onto the new drive-set. The point here is to have "backup" for your files, not for the Operating System files (which can be re-installed from CD/DVD).
Your "programs" can stay on the "current" disk-drive.
Sep 10, 2009 | Intel DP45SG Motherboard
In dell laptop
May be your Laptop requirments are not accoedingly; see below and match them, Specially the Vedio Card.
CPU: Any Intel or AMD processor - dual-core supported
RAM: 256 MB minimum, 512 MB recommended
DVD drive required
Video Card: NVIDIA, ATI, Intel i8xx and i9xx, SIS, Matrox, VIA. 3D desktop features requires NVIDIA GeForce or later, ATI Radeon 7000 or later, or Intel i810 to i965.
Sound Card: Any Sound Blaster-compatible card and AC97 – please note that Creative Labs X-Fi cards are not currently supported.
Minimum hard disk space: 3GB for a smooth installation- 4GB if you plan to use KDE 4.
Serial ATA: Most controllers supported in non-RAID mode and some in RAID mode.
If i was helpful, kindly do Rate!
Regards.
Jul 31, 2009 | Computers & Internet
Feb 15, 2009 | Intel Motherboard
RAID 1 not installing with WinXP32
Did you run the RAID configuration utility?
Jan 20, 2008 | Intel D875PBZ Motherboard
Dec 07, 2007 | Intel D101GGC Motherboard
Computers & Internet Logo
74 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
