Question about Pioneer Elite PRO-111FD 50 in. Plasma TV
HOW TO TURN ON SUBTITLE FOR ELITE TV - Pioneer Elite PRO-111FD 50 in. Plasma TV
How can I turn on subtitle on my TV?
You probably want closed captioning (CC) in a language of your choice. This selection is made during initial set up and can be changed by returning to it. Subtitles are part of the material you are viewing and can't be changed.
Aug 24, 2016 | Televison & Video
I somehow turned the closed caption on. I don't know how to undo it.
menu > set subtitle to off.
Subtitle Turn the subtitle on/off, and change the language depending on the media.
see manual t ftp://ftp.panasonic.com/hometheater/om/sc-btt770_en_om.pdf
Jul 18, 2016 | Televison & Video
How do I turn on the closed captioning on my Toshiba SD 5000 DVD player
What happens when you press the "Subtitle" button on the DVD remote control several times after you insert a subtitle-enabled DVD?
If you don't have the manual handy for your DVD player, I've added a link for the Toshiba SD-5000KU. The Subtitle button is described on page 13, but the description only tells how to turn subtitles on. However if the programming is typical, pressing the button repeatedly cycles through a series of language options with "Off" at the beginning or end of the list. Otherwise, it may be programmed to enter a subtitle menu that you navigate with the direction arrows (page 14).
Toshiba SD 5000KU Owner Manual
Jul 03, 2017 | Toshiba SD-5000
I can't get subtitle to turn on. Zenith DVD player to play movie with Subtitle
What you want is Closed Captioning. It has nothing to do with subtitles. If you turn off the speakers in your TV, the CC should appear after a brief pause. If your TV is not equipped for CC, this approach won't work
Nov 11, 2012 | Televison & Video
Please tell me how to turn off closed captioning on DVDS?
DVD movie playing have words on the screen is call subtitle.Goto DVD main menu.Turn off dvd movie subtitle,now dvd disc playing,will have no more words on the screen.
Jan 04, 2011 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Hi, cannot permenantly swicth off subtitle on my Hannspree TV. Every time I change channel subtitles re-appe. Appreciate any guidance.r
Hi
Open the menu and go to features then subtitle.
Switch off analogue subtitle.
Scroll to 1st subtitle and then scroll through the languages until "off" comes up.
Repeat for 2nd subtitle.
Oct 30, 2010 | Televison & Video
Hi, how to enable subtitles for DivX movies from USB on LG 42LE5500? I connect USB, TV recognizes folder where DivX .avi file is but within same folder it does not "see" .srt subtitle. Also, in settings...
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
Aug 14, 2010 | LG 42LE5500 42 in. TV
Bush 26" hd ready digital LCD tv brought argos today have gone into menu to turn off subtitles but every time i change chanel there they are. I know by pressing to subtitle button i can get rid of them but...
To switch off sub-titles on Bush 26" HD ReadyTV - the following has just worked for me 19.1.10
1) Select Features on Menu options
2) Switch Analog Subtitle to Off
3) Change Subtitle Type to Hearing Impaired
Good Luck - Geoff - Newcastle
Nov 21, 2009 | Bush Televison & Video
Onkyo CS-V720 crazy subtitle
Turn off the closed captioning on your TV.
Apr 17, 2008 | Onkyo CS-V720 Shelf System
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
Pioneer Elite PRO-111FD 50 in. Plasma TV Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
