Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Picture problem - top of screen
It just started happening. At the tp of the screen where the information bar is there is about a 3 inch horizonal line that is not insync with the rest of the picture. Any suggestion?
Hi rz9z58, Unfortunately, I've had a look around on the net, and this is a problem that you can't fix yourself. It's to do with a rare fault in the software of the Bravia Engine. If you can still return it to Sony under warranty, then go for that - just contact their customer support to arrange it. If not, still give them a ring; the quote they give may be pricey, but not as expensive as getting a whole new set. If it really is too expensive, try to address a letter to the CEO explaining your discontent - nine times out of ten you'll get a profitable response. Saying all of this though, if you live in the UK you're entitled uner the 1979 Sale of Goods Act to take it back to the store you bought it from without a receipt for up to six years after purchase, and they're obliged to take it back. It's 'unfit for purpose'. If you're not, there must be something like that where you are...do look into it, as it could be the solution you need - the television must be, after all, relatively new. Apologies for the bad news, but as I say, I'm pretty certain that you can't do anything about this...it's just an instability in the software of a few machines. If this has helped, I'd appreciate an appropriate rating. Regards, badegine
Posted on Aug 10, 2007
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
Toshiba television, rear projection, HDTV. - Model #: 50H13 - Serial #: 15703904 - Chassis #: TAC 0360 Blue horizontal arcing line about 1/3 from bottom of screen, a few inches thick. Text...
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 15, 2008 | Televison & Video
Horizontal lines have started appearing, running all he way across the monitor screen....several close together abour 3 inches from the top, and one, sometimes two, about an inch from the bottom... I have...
what you are seeing ithe horizonal sync lines, have you tried to adjust the settings on this monitor, I would try turning down the brightness, and the contrast. There should be a menu button on the monitor to adjust it.
Nov 18, 2010 | Soyo DYLM2286 Monitor
BLACK SCREEN WITH A BRIGHT HORIZONAL 1/4 INCH
HELLO
This is called Field Collapse and usually caused by the frame/field output going open circuit and/or the componants that surround that part.
Call a service centre in your locality who put it right (:-)
Nov 22, 2009 | Sylvania Televison & Video
Horizonal lines
Unfortunately you can't.
This is what happens when you blow pixels on your monitor.
If it is still in warranty this will be covered.
If you are outside of your warranty then you will need a new monitor
Sep 26, 2009 | Acer AL1916W 19" LCD Monitor
How to find degree of horizontal symmetry of Image?
If you use Adobe Photoshop, you can use ruler tool. Just drag from the start point to the end point of your horizontal (as example horizon line from a landscape image). It will display the Arbitrary degree in bar (just below the menu bar).
P.S.: If this information was helpful, please rate this solution. 1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Mar 19, 2009 | Apple Computers & Internet
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
Picture tube problem
This problem indicates a defective vertical IC or dry solder joints on the IC connections.
Jan 27, 2008 | Televison & Video
KDF-E50A10 Sony TV Purchased May 06
IF THIS HAPPENS ONLY WHEN USING HD SORCE THEIR IS A MODIFICATION TO BE CARRIED OUT.IF NOT THE OPTICAL BLOCK WILL REQUIRE REPLACING.
Nov 10, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
141 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
