Question about Drills
Jobmate drillpress manual - Drills
Where can I get parts for jobmate 1500 pressure washer ?
This is from a Google search:
https://www.google.com/#q=jobmate+1500+pressure+washer+replacement+parts
Ebay is pretty good and you may get a gun extension that would fit and be more affordable.
Jul 03, 2016 | Garden
I have a Delta DP200 drillpress. The motor is scorched. Can anyone advise a heavier duty motor (e.g., 1/3 or 1/2 hp) that will work with the same 4-hole mounting plate? is it common practice to use older...
Motor amperage and HP go hand in hand. Get the biggest motor that will fit and you will be fine. Better too big than too small - the latter will have higher tendency to burn out with heavy jobs like yours did.
Aug 31, 2017 | Drills
I need a work plate for a drillpress #1000
If you have the 5 speed model the table number is BT1000-0005 and you can go to Clarkeusa.com to order this part. That is where I found the breakdown for the tool. Let me know if you need more assistance.
Mar 14, 2010 | Clarke Power Products Clarke 16-Speed...
Need a bearing for clarke metalworker BT 1029-1 drillpress I
could be either BRG60203 or Brg60202, I suggest going to clarkeusa.com and looking at the breakdown. You can buy a bearing at any repair shop if you can get the ID number off the bearing, it doesn't have to come from Clarke. Let me know if you need more assistance
Feb 28, 2010 | Clarke Power Products Clarke 16-Speed...
Jobmate 3 gallon air compressor parts list/diagram
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
Feb 23, 2010 | Air Tools & Compressors
I have a JobMate cordless drill and 2 batteries.
I found the Ryobi charger fits the jobmate as well.
Oct 20, 2009 | Drills
Jobmate 18 volt chordless drill charging
About 60 minutes...max 90 minutes. Do NOT leave it on the charger for hours and hours...that just cooks the battery.
And switch regularly between the two batteries...else the one that doesn't get used will die.
Jan 20, 2009 | Drills
Drills Logo
519 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
