Question about Craftsman Garden
Replace pull cord on model#917.377880 mower - Craftsman Garden
  • 1383 Answers
SOURCE: replace pullcord on troy built mower
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Posted on Jan 11, 2009
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
  • 100 Answers
SOURCE: Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Posted on Aug 14, 2010
ftcmoa691
  • 5 Answers
SOURCE: trying to replace pull cord for kee tm22 push
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Posted on May 13, 2011
How to replace pull cord on dr. field and brush mower
go to you tube and put replace rewind starter cord its easier than people think.
May 14, 2016 | Garden
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
Replace pull cord
Go o you tube on line, how to replace pull cord mower
May 24, 2014 | Champion International Champion& Small...
Replace pull chord
Depends on your make and model.
Some are really easy, some impossible.
The easy ones go like this.
You remove the top of the motor, which is held on with a few screws. You will then have a bowl shaped piece, usually metal, which you will turn upside down, and see the cord-winder reel inside the top of it.
You will remove the cord winding reel, and wind a new cord onto it. However, the cord winding reel is spring loaded, and it takes knowledge and experience to do that.
The harder ones, I cannot begin to describe.
Be blessed.
May 04, 2013 | Mtd 22" Yard Machine Push Mower
Pull cord broke of mower starter
Go buy part at Home Depot or wherever. Remove top cover. Remove pull cord housing. Install new pull cord housing. Replace cover.
Oct 09, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
How do you replace the pull cord on a Toro model # 20038 lawn mower?
remove old one, rewind coil and replace with new cord
Jun 26, 2010 | Garden
Replacing a pull cord on a Craftsman mower
u helped tremondous. thank you, being laid-off i need my mower
Mar 29, 2010 | Craftsman Garden
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Jan 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
24 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
