Question about Sewing Machines
Brother vx 1100
Needle and foot will not move when I press the pedal
5 Suggested Answers
  • 980 Answers
SOURCE: I have an older (alright, ANCIENT) Brother VX 857.
Have you made sure you have tightened the stop motion ?
Posted on Nov 08, 2009
  • 192 Answers
SOURCE: Have Viking Husqvarna #1+ sewing machine that when
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
Posted on Feb 09, 2010
  • 6 Answers
SOURCE: the bobbin and needle won't move when i press the
I own a signer simple and it is a great little machine but if not adjusted just so it will act up like this.
The three things that caused this were:
#1 tension on upper thread and bobbin casing were uneven.
#2 Thread was catching on bobbin casing (solution, generously oil the face of the casing where the latch to remove the bobbin is located.
#3 The material was too thick (denim, leather) or I was sewing through too many layers of fabric.
As a general rule of thumb with this machine I never sew through more than 4 or 5 layers. This is a great machine for quick fixes and mending, but if using for apparel and complex items it can be a bit finicky. I default to a sturdier machine in these instances.
Posted on Jul 20, 2010
jiub152
  • 32 Answers
SOURCE: on brother vx 1500 when press foot needle will not move
It's jammed, take off the face plates and completely unthread it. Take out all the jammed up thread and it should operate freely:) hope this helped
Posted on Sep 20, 2012
Brother 1100, was sewing , now it is froze, cant turn the wheel far either way, cleaned, wants to go but is stuck, I cant see any thread in bobbin plate but I think that is where issue is advise
You could check the bobbin winder shaft. If this is engaged the machine appears to have frozen while turned on. Move the bobbin winder shaft left, then right while checking the foot controller and you will soon know if this is the problem.
Nov 08, 2016 | Brother Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
On brother vx 1500 when press foot needle will not move
Sep 20, 2012 | Sewing Machines
Why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Mar 27, 2012 | Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
I am getting error message E4 when foot pedal is plugged in. Unplug the foot pedal and the machine goes back to normal with the exception that you really can't sew without the foot pedal.
Your reverse reinforcement stitch button was pushed or needle position was pushed while bobbin winder was moved to the right. You can download a free manual brother-usa.com and you will see all of the troubleshooting and error messages there
Sep 10, 2010 | Brother CE4000 Computerized Sewing Machine
Have Viking Husqvarna #1+ sewing machine that when filling a bobbin caused the bobbin to overfill and break. Now when pressing the foot pedal the needle will not move. I can manually turn and get the...
Feb 02, 2010 | Husqvarna Sewing Machines
Foot pedal is not working!
sorry no nothing about sewing manchines ,althought this could be a wire loose in the pedal to sewmanchine .
ah you can get a manual from here http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_index.html?reg=eu&type2=-1&prod=hf_xl2600i2610euk&c=eu_ot&lang=en&flang=all
if this helps
regrads
riz.
Nov 20, 2007 | Brother XL-2600
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
