Question about Dishwashers
Fisher paykel dw60dox
My dw60dox dishwasher comes up with ijklmnopqcancel....what does this mean?
Krazytech
  • 725 Answers
SOURCE: F4 error on fisher and
No increase in water
temperature during
wash cycle. --->
Faulty element.
Electronics controller
faulty.
Faulty temperature
sensor.
Check the heater thermistor and the wires to both...
Posted on Jun 16, 2008
reg501
  • 413 Answers
SOURCE: fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Posted on Jul 04, 2008
A-OK
  • 10 Answers
SOURCE: error 'u1' on fisher paykel dishwasher
Water Inlet Valve!
Posted on Nov 23, 2008
SOURCE: Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Posted on Apr 21, 2009
  • 3230 Answers
SOURCE: what is F4 error on
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
I have a fisher Paykel dishwasher and a e20 code came up does this mean it is blocked
Hi Vivianne
I found the definition of some error codes but I don't know if any of these will apply to your appliance:
Fisher Paykel Fault Codes
I hope this helps
May 29, 2016 | Fisher Dishwashers
What does F2 mean??
F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video you can buy for only $3.99 that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Mar 24, 2011 | Fisher and Paykel 23 in. DD603H SS...
The dishwasher will start for two sec and then they both stop and a red light comes on and starts beeping with motors running.
This indicates the flood switch has been tripped. The video in the link below explains how to access and repair single and double drawer fisher and paykel dishwashers. Its a really good Fisher Paykel dishwasher repair video it really helped me.
Fisher Paykel Dishwasher Repair Video Link
Mar 09, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Disher washer is giving a signal F1 for repairs Model DD603SS
F1 means flood. Below is a link to a video that will show you how to fix the issue if you want to download the video.
Good luck
Mar 01, 2011 | Fisher and Paykel DD24DCFX6 Dishwasher
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Our dishwasher displays F1 with a wrench???
check the water pressure is coming through first
Mar 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel diswasher f1 fault code
f1 fault code means the flood switch is activated. There is moisture at th e base of your dishwasher.
Dec 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher/ paykel dishwasher says F3
f3 water temp sensed at greater than 85 c or 185f check temp sensor or is element on all the time
Jun 29, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 Top washer isn't coming on
is the lock symbol showing in the lcd badge when it's not back lit can be hard to see ,if it,s showing push lock button till it beeps release immediatly now try power button or start/pause button
Jun 05, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
18 people viewed this question
Top Dishwashers Experts
