Question about Kitchenaid KUIC15PLTS 15 Inch Wide 25lb Cap Architect II Left Hinged Icemaker Stainless Steel
Ice maker black mold
We are concerned about the clear plastic going in and out of the water pan. The mold is growing inside the hosing. It's only two years old . We have pre-water filters to the units and water softeners ( Kinetico). Any suggestions? Thank you!
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
SOURCE: Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Posted on May 05, 2008
IFIXALL
  • 868 Answers
SOURCE: ice maker's ice taste funny
You may consider pulling out the ice maker and tossing it in the trash if you look at it and see that where the ice sits it's corroded or its close to a 10 year old in age (IT'S DUE TO GO OUT ANYWAY).Other than that:you have a 3% chance that the tube that goes to your ice maker is bad. Please Rate This !
Posted on Jun 12, 2008
  • 3 Answers
SOURCE: Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
Posted on Aug 05, 2008
SolutionGuy
  • 331 Answers
SOURCE: kitchen aid under counter ice maker
S, the interior light is timed. If you leave the door open for more than 5 minutes, it'll shut off automatically. Close the light switch manually (at the top up there) and hold for 5 seconds. After you release it, you may see a red LED where the clean light is... disregard for now.
Now replace all of the hoses you removed for cleaning. These can be cleaned using the "cleaning method" posted and labeled on the inside of you IM door.
Now go get some of this, or something similar and follow the cleaning instructions.
As an aside here... I ran a service call for a guy who did exactly what you did, except that he chose to go to Home Depot and get all new tubing. (!!!!) Well, the tubing didn't fit and even if it di it was routed improperly. Then he called me to come fix it.
Close to $200 later everything was back to normal. All he had to do in the first place was to maintain his IM like it was a swimming pool. Get the right chemicals and use them as instructed on the label.
Please don't misunderstand. I'm not scolding or anything like that... it's just that sometimes the simplest approach is the best approach. Your high dollar IM is a complicated and computer controlled piece of equipment, when you start pulling the guts out, the "brain" has a difficult time interpreting what your doing, that's all.
Let us know how it goes. If there are any additional symptoms, please let us know immediately.
Posted on Mar 17, 2009
Ice maker makes ice but don't dispense ice or water
Hello Greig;
My name is Peter. I am a retired field service refrigeration technician.
I do not know what type of ice maker you have. Some have wire arms on the side, some have a downward plastic curved arm and some have a paddle arm on the side.
Some ice makers when they harvest have a plastic ice mold that rotate and flex, others have a little heater that heats the mold then activates finger arms to rotate and sweep the cubes from the mold.
Bad Sensor? All ice makers have temperature sensors. The sensor activates the harvesting of ice cubes when it senses the cubes are frozen. On some plastic ice cube molds it is a white wire on the bottom of the mold. On the cast steel molds the sensor is in contact with the mold at the front end.
Bad Motor Module? All ice makers have a motor module. The module has a control board and plastic gearing for the motor with in the module. The motor module is the assembly in front of the ice maker. The motor module tells the water valve when & how much water to fill the mold. It tells the mold heater, on the cast steel molds when to turn on after it reads the temperature sensor and then it tells the motor when to start rotation.
Not all ice makers can be repaired. Most are solid state.
The ice maker with the cast steel mold can be repaired. Remove the ice maker - Unscrew the one screw under the ice maker. Loosen the 2 screws on top so you can lift up and remove the ice maker from the wall. With a small screw driver wedge in the wire harness connector to free the icemaker. Pop the front cover off (No screws). Unscrew the 3 screws on the motor module and remove. This part is replaceable. Inspect for Burn marks and broken gearing. Unscrew the 2 screws to the heater and mold assembly to access the sensor - this is replaceable. There is no way to test this sensor.
Nov 01, 2014 | Frigidaire Refrigerators
Mold growing around ice dispenser area. Cant figure out how to get to the mold .
Pull ice maker out and clean it. Then make sure you have a fresh water filter on water supply. Mold in the freezer is uncommon if its truly freezing inside. You have dirty water coming in.
Oct 13, 2013 | GALAXY Microsystems 25.4 cu. ft....
Ice maker won't fill with water
Well the ice maker itself is what calls for water. It probably is fried. The way it works is the ice maker basically sits in the freezer and waits until the ice mold reaches 28f. When it gets to 28f the ice mold thermostat closes the electrical circuit to the heater and the motor. The motor basically stalls out because the heater hogs all the power. As the ice loosens the motor does not need as much power and manages to move the ice till you hear a CLICK and that is what kills the power to the heater and the resulting surge moves the ice on around at an astounding snail pace not unlike watching grass grow. At near the end the water valve gets energized by a probe rubbing against a copper plate located behind the main drive gear. over time it gets to where the arcing sticks the probe to the plate and instyead of 7 seconds of fill time it fills for 25 or more seconds or just smokes up the puppy and burns the tip of the probe.
Dec 12, 2012 | Kenmore Side by Side Refrigerator
I have a GE Profile Arctica refrigerator - water is leaking from the punctured plastic hose going up to the water filter (plastic hose from the bottom of the solenoid goes into refrigerator assembly)....
Good day!!!!
Refrigerators with a defrost cycle drain the melted water from the evaporator coils through a tube or a hole into a drip pan underneath the refrigerator. The water usually evaporates, but most times the pan is removable and can be drained. If this path of water is blocked at any point because the drain hole or tube is crimped or clotted with anything, it will back up inside the refrigerator area and try to find a way out, usually under the crisper drawers. To fix this, clear the obstruction in the drain tube. The drain pan at the bottom of the refrigerator can overflow or get old, crack, and develop a leak. Other times, mold can grow in the drain tube and clog it. Most refrigerators have an ice and/or water system built into them. This means that you have a waterline attached to the back of your refrigerator and it comes out as ice or cold water. Anywhere that water travels through the refrigerator and freezer can turn into a leak. To find the leak, you need to follow the tubes that carry the water through the appliance and make sure that all connections are tight.
Leaking containers or spills in the refrigerator can be misdiagnosed as leaks. First make sure that there are no puddles of juice, milk, water, etc. on one of the large capacity shelves.
I hope this solution will be helpful...Thanks for using fixya..
Aug 31, 2011 | GE Profile Arctica 25.4 Cubic Feet...
We have a Kenmore Model 106.56569400 and the icemaker keeps dripping water out of the ice cube trays. Is there a way to remove the icemakere trays and clean them out? Why does it do this. We also find...
The plastic film is the epoxy paint that is sprayed on the mold that holds the water/ice. This is a clear indication that you need to replace that ice maker. Once you take the ice maker out, you'll know what I am talking about.
Aug 09, 2011 | Kenmore Side by Side Refrigerator
Ice forms on the bottom shelf of the frost free freezer. We have no ice maker. What could be wrong? It's seven years old. It's a Whirlpool
I expect that when you check - the drain tube behind the inside back wall of the freezer compartment is clogged with debris and / or ice.
First, disconnect the the fridge from power at the plug.
Inspect the evaporator pan under the fridge. It is probably dry. If not, empty it and replace it.
Gather some towels & rags, a wet vac if you have one and a blow dryer to defrost and soak up / pick up melting ice. Also get a flexible piece of wire (coat hanger will do), turkey baster and a pail or container. A small amount of bleach will be needed, too.
You'll have to empty the freezer compartment of food and remove the back panel to gain access to the pan and drain. Some freezers have a plastic shelf pan that covers and is screwed to the freezer floor - if yours does, you should remove it, too. Keep clear of the coil, heater and controls that are protected by the panel. Plan on two - three hours to do the work, and an additional 2+ hours for the freezer to get cold again if all goes well. It will take much longer if you do not accelerate the defrost process (chipping, use of a blow dryer, etc.). If you can store food in a neighbor's freezer - that will be ideal.
Next, defrost the freezer. CAREFULLY chip away ice on the floor of the freezer. Do no chip in the area that was behind the back panel. Direct the hot air from the blow dryer at the ice in this area instead. Use towels and wet vac to pick up the water. Fill the container with hot water, and fill the turkey baster with the hot water and discharge the hot water at the ice / drain opening to speed the defrost process. Try to keep splashing to a minimum. Remove the blow dryer from this area when using hot water to melt the ice. Once the ice ice clear, check the evaporator pan again. Carefully remove it. If no water is present, the tube is still blocked. Replace the pan and continue to melt ice in the drain and check again. Repeat as needed. it is possible that a spider has taken up residence in the drain pipe - or there is some mold growing inside it. Use the coat hanger to gently "snake" down the tube to clear any obstruction. Once water begins appearing in the evaporator pan, empty it again and replace.
Mix up 4 ounces or so of water and 1 once of bleach and draw into the turkey baster. Place the opening as close to the drain opening as possible and gently squeeze the mixture into the drain. The mixture will kill any mold, spider, etc. that has been growing in the tube.
Almost done, CAREFULLY remove the evaporator pan again after allowing enough time for the tube to drain and empty in sink. This is a bleach mixture so be extra careful not to spill anywhere that bleach will cause damage.
Lastly, clean up with disposable rags (don't ruin towels picking up the bleach mixture) and reassemble back panel and floor pan. Restock freezer and plug the fridge back into outlet.
I hope this helps & good luck. Please rate my replay. Thank you.
Jun 01, 2011 | Refrigerators
Drain Pan overflowing and water is leaking in refrigerator I can see drip pan overflowing but I do not know how to get to it
remove the back panel inside the freezer,then defrost the pan,then take a length of stiff wire and clear out the drain line from there down to the pan in the lower area near the compressor,as theres probably lime,mold growth build up in the drain line plugging the hose restricting draining of defrost water
Mar 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
Frost free freezer forming layer of clear ice on floor of freezer
This sounds like clogged drain / hose in the freezer compartment, here's why:
When the defrost circuit turns on, the compressor turns off. The defrost coil melts frost that collects on the freezer coil and drips in to a small pan located below the coil. The pan is formed so that the water that drips in it can flow to a hose connected under it. When the defrost cycle completes. the compressor runs again, bringing the temperature in the freezer to about 0 again. Any water remaining anywhere in the freezer will turn to ice very quickly.
If the hose should become clogged with ice, or slowed by mold, bacteria, etc. - water flow will be slowed, and / or eventually stopped. Ice will become thicker and thicker on the floor of the freezer as there is no place for the water to go.
A service manual for the appliance would be a good idea, but may not be required. You'll need to unplug the freezer and empty the contents. Defrost manually with a hair dryer or other heat source. If you decide to chip away ice, do so carefully.
The defrost and drain area of most refrigerator / freezers are located behind the rear panel of the freezer compartment. This is where the manual would indicate where the parts are located. Remove any ice maker installed if needed to remove the back panel.
Defrost any ice previously hidden by the panel. Chipping ice here should be a last resort, as sharp edges can damage cooling coils, tubing and the drip pan itself. Use a turkey baster filled with hot water to direct a stream at the area of the pan filled with ice. Hot water will likely have to be directed down the opening on the pan to melt ice in the hose as well.
Once the ice is cleared, mix about a 10% to 20% solution of bleach and water (1/2 ounce bleach to 3 ounces water) and direct down the drain hose. This will kill and inhibit further growth of mold and bacteria in the hose, which should help it drain water quickly.
Re-assemble and plug into power.
I hope you found this Very Helpful. If you need more help, ask again - but include the freezer manufacturer's name and model number. Good luck!
Dec 03, 2009 | Freezers
No ice or water coming from fridge door
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring.
Nov 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kitchenaid KUIC15PLTS 15 Inch Wide 25lb Cap Architect II Left Hinged Icemaker Stainless Steel Logo
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
