I bought an Olympus om-G(om-20) 35mm SLR film camera and I don't know how to use it, I will be starting a black and white Photography class here in a couple of weeks and I wanted to at least get to know it and mess around with it for a bit before that. I don't even know how to get the back door thing open to put film in. Does anybody know where I can get a users manual or maybe someone knows some tips for basic operation. Thanks!
First you have to rewind the film (some cameras rewind themselves automatically, but I don't think this is one of them). You do this with a little crank that unfolds from the top of the knob on the left of the camera's top plate (left as you hold the camera for shooting pics). You need to release the film first by pressing a recessed button on the bottom plate of the camera. Once the film is rewound into the canister, you open the door by pulling upwards on the little crank until the whole of the back of the camera opens up.
I am puzzled as to how you loaded the film in the first place without knowing that last bit.
You can download a manual for the OM-1 from http://butkus.org/chinon/olympus/olympus_om-1/olympus_om-1.htm
The OM-1MD is the same camera as the OM-1 with the added provision for taking a motor drive to advance the film automatically.
The OM-1n is the same as the OM-1MD with a redesigned film advance lever, a flash ready/sufficient flash LED in the viewfinder, and automatic X-sync regardless of the position of the FP/X switch, when it is used with a T-series flash unit mounted on Flash Shoe 4.
These are no longer available new. You'll only find one if you buy a non-functional OM2SP for spares. Not many OM2SP's are still working, so it's not usually too difficult/expensive to obtain even a cosmetically perfect but non-functional example from auction/classified websites.
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
You can use the lens from your old OM camera on the EVOLT E-410. You would need to purchase an MF-OM-1 adapter to make those lenses fit the new digital SLR camera. Also when using those lenses the camera would need to be used in Manual mode as there is no auto focus capability when using the old OM lenses.
By manual zoom lens I am assuming you mean a film camera lens. If it is one of our OM 1 or 2 lenses they can be used on our Olympus digital SLR camera but you will need to purchase an MF-OM1 converter to be able to adapt those lenses to fit on our digital SLR camera. Then you will only be able to shoot using those lens in manual focus mode. Auto focus mode will not be available.
