Question about RCA RTD317W Theater System
Speaker makes buzzing noise sometimes
The speaker that is hooked up with the green wire will be working just fine and then it starts buzzing. I have tried to rehook the wires up, but after about 10 minutes use, it starts buzzing again.
2 Suggested Answers
  • 661 Answers
SOURCE: speakers make a buzzing noise
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Posted on Feb 02, 2011
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Why am i not getting any sound when i hook up a speaker directly up to a speaker channel its only a buzzing sound
If the radio is powered on, put a cd in, or make sure you are on a known good radio station and connect a speaker directly to one of the pairs of speaker wires on the radio. let us know if there is still just static.
Nov 07, 2013 | Farenheit TID735NRBT Car Video Player
The sound on my garmin zumo 550 is not working right it has been working fine. But this morning when I hooked it to my Harley ultra classic it was reel low upon further check it was only coming through...
sounds like the Audio patch cord, i had around 5 of them that do that ...sometimes i hear the music thru one speaker, cracking noise sometimes it works when the wire is twisted, but i would try a new patch cord first.....my patch cord worked fine on some stereo units others break up
Nov 07, 2010 | Garmin zumo 550 GPS Receiver
Audio buzzing
check where your pluging the red sounds like your pluging a video signal into an audio jack or your red cable ha an open ground
Dec 22, 2009 | Vizio L37 Television
Kenwood KVT-815DVD Unit only buzzes
I bought a Kenwood KVT-815dvd player and got everything hooked up to only find out that it had a security code. The problem now is that I got it from a pawn store and they did not even know that it had a security code on it. So is their a way I can bypass they password or just reset the whole unit so that it does not have one. Also, where is the memory for this unit?
Thank you
Nov 19, 2009 | Kenwood Excelon KVT815DVD Car DVD Player
Replacing the Stereo in an 1995 Audi A6 Quattro....
I assume this is an aftermarket radio and you don't know the connections?
Normally, the red is + and the black -. A yellow wire usually is a feed to a power amp to turn it on when the radio goes on.
On the speaker side, you should have paired up wires like:
Yellow solid and yellow w/black stripe
Brown solid and brown with black stripe
Green soild and green with black stripe... you get the idea. The solid color wire is the positive and the balck striped match is the negative.
There should be 8 speaker wires altogether to give you L/R fron and L/R rear.
If you don't know which terminal is positive and negative on your speakers, try this;
Take a 1-1/2 volt AA battery and connect it to a speaker momentarily ( I do mean momentarily or you'll blow it). If the speaker cone moves out away from the magnet then the terminals match the polarity of the battery - and +.
If the cone moves towards the magnet the polarity is reversed. It is important you connect the speaker phasing (polarity) correctly other wise you will get poor bass output.
Whatever you do, do not ground any speaker wires!!!!
Aug 22, 2009 | 1995 Audi A6
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Buzzing noise
Of course it will stop buzzing when you mute the speakers. From the limited description, it could be anything from a power supply to loose wires in the system between the speaker leads and the motherboard. Best bet is to take it in to a technician and get a pro's answer. If he wants to charge more than what it's worth to you, get a new one.
Jun 19, 2007 | RCA RS2640 CD Shelf System
Speakers making loud buzzing noise
From your alternator, Make sure none of your RCA's are near a power wire, check your grounds as well.
Jan 09, 2007 | Pioneer TS-D690R Coaxial Car Speaker
RCA RTD317W Theater System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
