Question about Mitsubishi VS-45607 45" Rear Projection Television
Panasonic tv number model is pt60cl14
Panasonic tv pt60cl14 i changed the lamp, ballastra and thermo fuse and not turn on, need help to fix. you know what is the other promlem
    Genius:
  • 1,153 Answers
Is this set Panasonic or Mitsubishi? Does have any lights on or completely dead?
Posted on Sep 14, 2007
Panasonic schematic th 42px7a
Schematic diagrams are in PDF, and cannot upload by this window. If you wish to get some details, check this link. Do want more, try to download the repair manual to this model TV, by internet. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 08, 2013 | Televison & Video
Thermo fuse box noise, screen not on
have u replace the lamp on this unit , if not that would be ur problem the lamp is at front of ur tv just remove the speaker grill and u would see a small door , use a phillips screw driver
Apr 12, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do I reset the metter for a new lamp?
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 06, 2009 | Panasonic PT-52LCX66 Projection Television
How do you reset the lamp clock on model number
I hope this information allows you to resolve this issue.
asnowman
Nov 26, 2009 | Panasonic Televison & Video
Replaced lamp-orange lights still flash.....lame!
Yes, Turn On TV, press and hold Volume Down button on TV front and Split button on remote at same time for 6 seconds to reset lamp timer in TV.
Sep 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
I need to change the lamp in my tv show me how
woodguys, how can we help you if you don`t give us the model number ???? can`t look up anything if we don`t know what make and model to look up, they are all done differently, I`ll be glad to help if u give the info, video-tek
Jun 05, 2009 | Panasonic Televison & Video
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Brief picture for 30 seconds, then lamp button blinks
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Dec 22, 2007 | Panasonic PT-40LC12 40" Rear Projection...
How to change fuses
i'm sory sure why did you change the lamp? mybe the lamp was non put in straight and the door safty switch was not right. need more info. WHAT WAS THE SIMPTOM BEFORE YOU CHANGED THE (HOPEFULLY DLP TV YOU ARE WORKING ON)
HOPE WE CAN HELP DOC
Nov 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
110 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
