Question about Boss ME-70 Guitar Multiple Effects Pedal
BOSS ME 70 GROUND HUM
GROUND HUM NOISE
What repair do i need in my BOSS GT-10 too much ground/humming sound even adjusted the built-in noise suppressors?
Take it to a tech. It probably needs a few op-amp swaps. It's a long shot, but it can be worth it.
Sep 20, 2015 | Boss Music
When used, it seems to effect guitar amplifiers and cause a strange sort of a chorus sound, like somehow the unit is bleeding into the other amps.
it maybe interference picked up through an unsheided or poorly sheided cable or through single coil type pickups rather though the amp itself. You might also try get your power for the amps and this unit through different circuits.
Mar 20, 2015 | Roland Boss VE-20 Vocal Performer
Contact boss
BOSS ME70 Factory Reset.
Just do this:
Jun 11, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
May 06, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
My Boss ME-70 Pedal doesn't fade out smoothly
Hi
Not an answer but a repeat of your question. Did you manage gto fix this as I believe my unit may suffer from the same problem. Thanks
Apr 17, 2013 | Boss ME-70 Guitar Multiple Effects Pedal
How do I factory reset a BOSS ME-70 effects pedal
press pedals 3 & 4 at the same time to swtich to Manual Mode. Hold down EDIT/EXIT and press the MOD pedal. Press WRITE twice.
Sep 04, 2011 | Boss ME-70 Guitar Multiple Effects Pedal
Hello - I have a Boss RC-2 Loop Station. While I enjoy the pedal's capabilities, it almost always creates an unwanted hum and sometimes an electronic pulse in every amp I use it with. (I typically keep...
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
Jul 20, 2011 | Roland Boss RC-2 Loop Station Stompbox...
When I connect the Mackie 1642-vlz3 from the "direct outs" to the line level inputs of the D3200 there is noise/hum (except for channel 1). There is no noise/hum in the XLR inputs. I have two...
Make sure ALL of the interconnected equipment is powered from the SAME receptacle to avoid ground loops due to the safety ground. DO NOT Use two wire power or use ground lifting plug adapters. Make sure you use balanced lines, either XLR or TRS cables. Do NOT use TS cables.
Jun 01, 2011 | Korg D3200 Digital Studio
I have NS-2 Noise Suppressor Pedal, this works fine but in some moment make a radio noise (hum) and the output signal comes down (like turns the volume to 0) ... I don't know what it is, I'm going to...
The probable problem is poor connections at the input and/or audio output jacks.
Usually the power supply will fail either on or off which is sometimes cause by a bad input power jack.
In any case, the problem is likely internal and will require repair.
Aug 06, 2010 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Hum in Lowery Organ E 90 H
Service manual will probably be hard to find.
I would first find if the hum varies with the expression pedal. If not, problem is in the power amplifier section. I would look for heater/cathode shorts or leakage in one of the tubes... DO NOT trust tube checkers to spot shorts!!! Swap like tubes and look for a change.
A broken ground wire or shield on coax to the expression pedal would be a likely candidate as well.
Jan 09, 2010 | Boss Micro BR Digital Recorder
Boss ME-70 Guitar Multiple Effects Pedal Logo
130 people viewed this question
Top Boss Music Experts
Michial Gueffroy
shaun taylor
Robert Graf
Are you a Boss Music Expert? Answer questions, earn points and help others
