Question about Refrigerators
Kenmore bottom freezer refrigerator model 795.7130 control panel displays Ernagemylife com
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
SOURCE: Just bought a kenmore elite bottom freezer trio
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
Posted on Jul 12, 2009
mgprice
  • 744 Answers
SOURCE: Kenmore bottom freezer refrigerate leaks
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 14, 2009
Testimonial: "Greatly appreciate yor help, Mike. Found screws to remove back panel, but the ice maker is plugged into a hole in panel can this be unplugged?"
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Posted on Sep 25, 2010
Ice cube maker not working. digital display not
The ice fan is frozen. It is located behind the rear panel inside the freezer2.gif drawer. I had the same problem with an LG refrigerator in November 2008 that was fixed under warranty. (There is a Kenmore model that is made by LG.) They replaced the fan and housing, and the panel duct assembly (both because a design revision provided a way to drain the water that was freezing the fan), and the main controller board (presumably because there was a new defrost program, but also because of the Energy Star settlement.) If your refrigerator is out of warranty, you can remove the freezer drawer to get at the panel behind it. Remove and defrost the fan housing. Drill some small holes in the bottom of the fan housing for drainage. Put it back together and see if that solves the problem.
Oct 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Just bought a kenmore elite bottom freezer trio model and display panel shows o ff. Expect this means whole unit is off but manual does not say how to turn ON in the setting the controls section of manual....
Jul 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works but refrigerator is staying at 50 degrees
Is this a French door unit? Do you see excessive build up of frost in the freezer on the back panel? Is that evaporator fan motor running? That is what circulates the air from the freezer to the refrigerator.
Apr 11, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite trio 596.76539500 control panel says OFF.
On a Kenmore Trio 78729 made by LG, open left door and push the Ultra Ice and Refrigerator button simultaneously for 5 seconds. The display will change from 0 OFF to temperature settings.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Control Pad displays Er CO.
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Jul 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
