Question about Philips 50PF9630A 50 in. Plasma Television
Vertical white line
My Philips plasma is a replacement for a broken Akai edtv. The difference in picture quality is amazing, however, there is a thin white line that runs top to bottom, about 5" right of center. Is there a simple fix?
  • 4 Answers
Dont touch it just keep it running. one of the days you wake up and it will vanish just as it appeared without cause. This is because it has happened to me once with my Philips 42. the don
Posted on Aug 10, 2007
I have LG 46 Inch 3D Led T.N which i had purchased 2 years back , but from few days it started showing a thin vertical line on left side . this line is widening . can any one tell me what could be the...
Vertical lines aren't generally caused by a bad panel, horizontal lines are...remove the cables going from the Tcon board to the panel, both at the tcon and panel, wipe them down and re seat them and see if that takes care of the issue, if it doesn't replace the timing board, I don't think this is a panel issue
Dec 23, 2017 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Only get black & white, double images
bad power circuit may cause such problems.
may be power ic or bad capacitors.....
Aug 18, 2017 | Philips 50PFP5332D 50 in. Plasma...
I have a thin vertical line about 9"from left side runs top to b
either a bad buffer pcb or display panel, 12 month warranty call panasonic quick
Aug 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
May 24, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Got a blue vertical line on me plasma
Ohh you have a problem with the PLASMA gass ( RGB balance failiure )..don't switch it on again run to service center....
causes ;- heavy nonstop use, heavy impacts , can have probs from LG factory , we have nothing to do the only advice is run to a service center...don't try to do it yourself ....
so i identified your prob...PLEASE VOTE ME AS "FIXYA" (Successfully solved) for my help
May 29, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Repair Akai TV
the snow is just because of poor quality signal
the signal coupler which is in the tv might be bad or your dish needs to be reset cause of the wind
Mar 12, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Open Questions:
Philips 50PF9630A 50 in. Plasma Television Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
