Question about Brookstone Outdoor Wireless Speaker Computer Speakers
Speaker not working power light on
Power lite on but no sound what to do next?
My technical sug90 stereo has no sound and next to volume control yellow lite on says overload
Could be caused by a faulty speaker or cable. Make certain that all speakers and wiring is good. Then disconnect the unit from the mains and try again.
If the light does not go off the circuit is either faulty or there is a power amp fault.
Sep 21, 2017 | Audio Players & Recorders
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
No sounds device
Hello emedianannab, You have to "Update the Drivers" or you will have other problems with "Hardware" too.
Part1
Do a [Microsoft Update] from the "Start Menu," paul7of9_86.jpg scroll in the "All Programs."
Do a "Windows Update" Type: windows update, in the Start Search {box}.
Go to the "Control Panel" from the Start Menu," open the Control Panel,
scroll to find "Hardware and Sound," and click on the "Sound" applet.
Open the Speakers Properties, click on the [Driver Button] and "Update Drivers for the Speakers"
Part 2
  • [Right / Alt] click on the Volume Icon. paul7of9_82.jpg
  • Once the 'window' open!
  • Select the "Playback Device" shortcut.
  • Next, {2x click} to open the [Speaker Properties] 'window.'
  • Now, check the (Device Usage) to make sure that it is [Enable].
  • Next, check the "Levels / Enhancements" by clicking on the buttons...
  • Make sure "that all the levels on the 'Sound are up!
  • Next, go to the "Drivers" by clicking on the "Properties" button.
  • Select the [Driver] button, and "Update the Drivers.
  • ***Note: "If any of the Driver {Areas} are "Grayed-Out," than this mean that the "Drivers are up to (Date)." Click on the "OK" button when finished!
  • Next, "Restart the Computer."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 24, 2011 | Computers & Internet
Want to connect JBL platunum series speakers to Dell Inspiron 560 with Windows 7. There is no sound coming from theses speakers on this system. They worked with HP compac.
Hello there,
here is the sound card for the DELL
Sound Card Integrated 7.1 Channel Audio up to Creative SoundBlaster® X-Fi Xtreme Audio (D)†
that means you have a sound card and the port should be in the back and should be green.
Audio front panel - one headphone and one
microphone connector
This is for a headset .
Here is what i would try make sure the speakers are powering by turning on the right speaker the LED should light up if it is then it has power, Next i would try the back of the PC speaker port , if you have everything connected correctly we move onto the next step.
Ok go to
Control panel
Hardware and sound
then click on the green sound link that should pop up a window to configure the speakers, you should see the devices in the list and be able to configure them if you do not let me know and i can help you with the next step.
thank you don't forget to Rate
Jan 25, 2011 | HP JBL Platinum Computer Speakers
No sound when computer is being shut down or playing music on windows media player. button next to power button not lite up. push mute button back off still cannot get a sound.
Check the volume controls and sound properties. Make sure that the master volume ins not in "MUTE".
Double-click the speaker icon on your tool bar. The volume controls will appear.
Check the Sound properties:
Right-click the speaker icon > Adjust Audio Properties:
Audio tab > make sure to select the right sound device.
Thank you and good luck!
Sep 12, 2010 | Dell Latitude D600 Notebook
The sound on my ds lite seems to be tinny and seems to have lost its suround sound effect
YOU HAVE TO BUY A NEW SPEAKER AND KEEP IT TURNED DOWN NEXT TIME OR US HEADPHONES.
Feb 23, 2010 | Nintendo DS Lite Console
Won't work after re-installing Boston speakers
would try it with the correctly rated fuse as there may not be enough wattage / current to power the bass unit with a thin wire.
Also how long ago was it flooded as it may take quite a while in a warm area to dry off completely ?
Apr 11, 2009 | Boston Acoustics BA735 Computer Speakers
Seems to be no power to speakers.
Disconnect green speaker jack from computer and see if you get a green power light on speakers. If the speakers indicate they have power, your sound card or circuit is shorting out the speakers. If you still have no power to the speakers when disconnected from computer, then no green light means no power to speakers. Either you’re A.C. adaptor is bad or the speakers are shorted out. You have 2 options:
1) Replace A.C. adaptor.
2) Replace speakers.
If you buy new speakers, make sure that they have their own power source (A.C. adaptor).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell A215 Computer Speakers
No sound from a sony stereo receiver.
Hi there
Have you checked that the speaker on/off switches have not been bumped also. They are often at the left hand end of the amp next to the power switch and easy to turn on. A Tape monitor switch engaged will also give you those symptoms. Check them out and get back to me here if you cant find the problem
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
SOUND ON MY DS
replace the ribbon to the top screen. Look for "ds lite top screen" on ebay
Oct 22, 2007 | Nintendo DS Lite Console
22 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
