Question about John Deere gator driven clutch for xuv 825i & xuv 855d gators
Adjusting clutch john deere 2011 825i engine rpms are way to fast at mid speed what can i do to slow down rpms
SOURCE: JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Posted on Mar 21, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
  • 146 Answers
SOURCE: my john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Posted on Jul 04, 2010
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
My 2007 polo gti 2007 model is very slow and it can go as fast as 100km/h
so exactly what is the problem
is the engine rpms high but not fast on the speedo or are the engine rpms limited to around 2000
you replaced a clutch kit so if the rpms are high but not fgast on the speedo , the clutch is slipping--check clutch master cylinder, /cable for correct operation
if the engine rpms are limited it is probably in limp mode so have the fault codes read
Sep 02, 2016 | Volkswagen Polo Cars & Trucks
John deere la175 deck blades spin quit and fast. hook up to pto and engage engine boggs and tries to die
Maybe the travel speed is too high for it or the fusible link in starting circuit is blown.Check and adjust timing belt tension if necessary.Visit john deere expert or dealer.
Jul 21, 2016 | John Deere Garden
If brakes are not locked together on steep ground the John Deere tractor will kick out of 4wheel drive and run away.
Operating - Operator's Manual - John Deere
manuals.deere.com/cceomview/...A9/Output/OMM139226_A95.html
Slow down before you make a sharp turn or operate on a slope. ... Before starting engine to drive tractor, adjust operator seat to desirable position. ..... If lock does notdisengage, depress one turn brake pedal, and then the other. ... The 2-wheel drive (2WD) / 4-wheel drive lever (A) enables the tractor to be operated in two or ...
A Guide To Safe Farm Tractor Operation - National Ag ...
Nov 23, 2015 | John Deere Garden
Is there any way to adjust the hydraulic system on the blade for an electronic over hydraulic dozer John Deere just takes a bit of getting used to but it would be nice to be able to tweak it I believe...
sure slow the engine speed down , that will reduce your hydraulic pressure , then when u get used to it you can speed it back up , besides I use the "float" more often on the blade , unless your using it to laser grade
Mar 17, 2015 | John Deere Garden
My 1997 john deere just dont run as fast and hard
check your throtlle cable ... it is very possible that if the engine runs fine just doesn't run as fast as it used to that you throttle cable has slipped in the clamp and you need to adjust it ...
Aug 19, 2009 | Garden
Peg Perego John Deere tractor 12volt will only work in reverse. Will not go forward in the slow or fast speeds
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Aug 16, 2009 | Peg Perego John Deere Turf Tractor
PTO clutch slipps when warm on John Deere Model 112
I had that exact same mower about 20 years ago. The clutch if i recall correctly is like the clutch on a automotive AC compressor, its an electro magnet that pulls the clutch plate in, so if its slipping its probably just time for a new clutch. As far as i can remember, and like i said its been 20 years, there is no adjustment on the electric clutch because it has spring pressure to compensate for wear, so as it wears down it still engages, but if your slipping its probably just beyond its wear limits and needs to be replaced.
Jan 11, 2018 | Garden
Towing my boat /seems like its slipping/new clutch?
Try having clutch adjusted first, then you will know if clutch has been slipping.
Let me know if this helps. MMP
Jun 15, 2008 | 1987 Ford Bronco II
John Deere gator driven clutch for xuv 825i & xuv 855d gators Logo
82 people viewed this question
Top John Deere Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a John Deere Office Equipment and Supply Expert? Answer questions, earn points and help others
