Question about Toshiba gigabeat S MP3 Player
Gigabeat has froze completely
Hey all, I've been using the Toshiba Gigabeat MES30VW for over 3 months now with no problems. When I turned it on today the screen is saying "The battery is low. The Portable media center will turn off soon" and them I'm prompted to press ok. I attempted to press ok but no response. I attempted to turn the device off but no response. I attempted to charge the battery but no response. I attempted to hold the power button in hopes of a reset button but no response. Right now the screen is still showing the error message and is not going to stand-by mode. The screen is still on and bright with the error message. Any solutions to this?
    Problem Solver:
  • 7 Answers
Turn off the battery with a toothpick or pencil then turn it back on. You can do this on the bottom side.
Posted on Nov 08, 2007
Thank you so much
Posted on Oct 09, 2008
SOURCE:
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
How can I get installation CD for my Gigabeat model MES30VW, my previous computer died and I do not have disk
go to the website for toshiba using google or just google "gigabeat room 3.0 " it works fine with vista just follow the instructions
Sep 09, 2009 | Toshiba Gigabeat MEG-F20S MP3 Player
The problem with my Toshiba Gigabeat is that it does not seem to turn on after not being used for about 2-3 months...I need some advice
Batteries may need to be recharged or replace.Have U try reseting the unit. There must be reseting button somewhere on the unit.
Sep 08, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
Help! 30 GB Gigabeat won't hold a charge and seems to be wiped :(
Sounds like a built in glitch ... You might want to take it back under manufacturer's warranty and get a completely different MP3 Player/iPod, because it sounds like a scamming item - for $400 I'd demand answers.
It may sound a bit cheeky, but I find reputable models, like Goodmans, JVC and Sony work without a problem, and buying cheaper models with mass GB space would seem a bit too good to be true.
Jul 20, 2009 | Toshiba Gigabeat S30 MP3 Player
File transfer Problem
Ok, I figured out a solution on my own.
Remarkably simple - all I did was reformat the player again and then reinstall windows media player.
Although in my travels I came across an article which may help users with a similar problem: http://support.microsoft.com/kb/911091/en-us#appliesto
Apr 20, 2008 | Toshiba gigabeat S MP3 Player
Driver files for Toshiba Gigabeat MES30VW
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Feb 28, 2008 | Toshiba gigabeat S MP3 Player
Contents list
Create a playlist of the songs you want. You will still be able to browse by the other categories like artist, album, etc...
Oct 22, 2007 | Toshiba gigabeat S MP3 Player
Gigabeat froze -_-
sound like the hard drive connection came apart.(wire came off of the board or the drive) you will have to open it up to fix it.
Feb 11, 2007 | Toshiba gigabeat S MP3 Player
Iva (toshiba gigabeat 10gb)
If you reformated the mp3 player's hard drive, the problem probably is that it can't find it's firmware which is supposed to be located on it's hard drive. To fix this, simply copy the GBSYSTEM folder located (usually) in C:\Program Files\TOSHIBA\gigabeat room 2.0.2 to your mp3 player's root.
May 26, 2006 | Toshiba Gigabeat MEG-F10K MP3 Player
Toshiba gigabeat S MP3 Player Logo
203 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Andrew Taylor
Andrew Taylor
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
