Question about Microwave Ovens
CGLMV169 fuse location
Can't find fuse
How to get to fuse in my jmc7000adb
On this model, the fuse is located in an inline fuse holder is the wiring harness.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 24, 2012 | Jenn-Air JMC7000 Microwave Oven
Keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
In many brands, there is a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Oct 18, 2012 | Microwave Ovens
Whirlpool gold YGH5184XPS-0 fuse location, I believe i blew a fuse and cant find the location, the thing worked fine and then i shut the door and lost all power, either the door latch is broken or the...
Mike - Unplug the unit and unscrew about 4 screws on the top and then the side panel and the fuse will be in that location.
Note: If the fuse looks brown, it's definetly blown, you can get the same fuse at your local Radio Shack for about $0.97. hope this helps
Aug 14, 2012 | Whirlpool Microwave Ovens
I have microwave oven cglmv169 the fan is not turning?
I think that it would be the fan belt has broken......cheap and easy to replace but make sure you unplug microwave first eh!.....
Mar 25, 2012 | Frigidaire Microwave Ovens
I have an over the range DAEWOO MT1510W Microwave i think the fuse blowed my manual doesn't show where it located at
The fuse probably is internal. It may be necessary to remove your OTR microwave to get access inside.
Jan 13, 2012 | Daewoo Microwave Ovens
How to check control panel fuse
It depends of course on the brand and model number, but here are some basic guidelines.
On a counter top microwave, the fuse is usually located between the door switches or on the noise filter board near where the AC cord enters the chassis.
On an over the counter model, the fuse is usually located behind the grille or control panel, or sometimes on a noise filter board near where the AC cord enters the chassis.
Some tips here:
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
We're
Dec 15, 2011 | GE Profile Spacemaker Over-the-Range...
Where is the fuse on my microwave Electrolux PLMV169DCD located?
We have three service manuals covering the PLMV169 series, which you can download free:
http://www.microwavedisplay.com/plmv169dcc_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
They're all pretty similar.
You can usually find parts from the Pros here.
If not, contact Electrolux at the phone number on the front of the service manual.
It may be the C/T fuse (thermal fuse located above the magnetron) or the oven cavity thermal cutout, located on the top of the cavity.
Accessing these two parts for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Electrolux / Frigidaire owner's manuals and installation instructions
here.
It may also be that there was a power surge which damaged the control circuit board, activating the built-in surge protection.
This is not resettable. The circuit board has to be repaired. We do that for $39.95, details here.
Dec 03, 2011 | Frigidaire PLMV169DC Microwave Oven
Won't heat food on any setting. Could it be a fuse? Where would it be located? Don't have a manual.
Fuse will be inside the oven.And with replacing fuse ,you need to check the cause of blowing the fuse.Check the capacitor and transformer (physically).If they look deformed .Then change it followed by the fuse.
Thanks
Please rate my work
Sep 17, 2011 | Daewoo KOR-630A Microwave Oven
My jvm 1861 oven does not power on at all. how do i disassemble the control panel to replace the fuse
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
The fuse should be accessible after removing only the grille, with no need to remove the controller.
According to a similar model's service manual:
"The fuse is located on the upper duct mounted to the Noise filter.
1. Disconnect power and remove grille.
2. Replace the fuse."
You can find handy exploded views and order parts by model number
here.
May 25, 2011 | GE JVM1860 Microwave Oven
Microwave turntable not turning, not heating up I have a fuse to try to replace, but don't know where it's located. Model # is 565. 69421
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';';
May 21, 2011 | Kenmore 63252 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
