Question about SonicWALL PRO 300 Firewall
Sonicwall Pro 300 DMZ Problem
I configured a dedicated Windows Server 2003 Dell Poweredge 400S server to be an FTP server. I set up the DMZ port as 172.16.0.1 w/255.255.0.0 subnet. The public IP is 67.103.165.4, which is on the same subnet as our WAN IP, 67.103.165.3. The internal static IP of the FTP server is 172.16.0.2. The default gateway for the FTP server is 172.16.0.1, address of DMZ port. I updated the router thru the Web management console and created a rule to allow all sources FTP access to the DMZ port. There is no firewall (not even Windows) on the server. From any computer in our LAN, 192.168.77.0 w/255.255.255.0 subnet, I can FTP into the FTP server. However, I cannot FTP into the public IP. Also, the FTP server can not see the Internet. Pinging the FTP server from the router and any LAN computer is successful. The FTP server can not ping any computer and not 172.16.0.1). Don't understand what could be going on. The FTP site is configured to allow all computers anonymous access. I will worry about adding security when after I can FTP into the server.
    Scholar:
  • 133 Answers
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Posted on Sep 07, 2007
    Problem Solver:
  • 13 Answers
The question is whether the Sonicwall is acting as a firewall for you network or it is also the router for your Internet access as well as the firewall. It is important which device is doing the address translation for the FTP server.
If there is a router between the Sonicwall and the Internet, there is a need to configure a static route on the router to route the external IP of the FTP server to the external IP address of the Sonicwall.
Otherwise, you should segment you public (or get a specific routing pair from your ISP and the have the ISP route you public network to the IP of the Sonicwall).
You must remember that routing should be consistent both ways - to the Internet and back.
Also remember the whe doing NAT, the IPs of the NAT should be routed the the device doing the NAT.
Posted on Feb 08, 2009
How can i istall windows server 2000 on Dell Poweredge T300
Windows 2000 is not supported on this machine. The closest you could get is using a hypervisor XenServer or VMWare ESXi and then installing Windows 2000 on a virtual machine.
Jan 26, 2015 | Dell PowerEdge T300 Server
Second hard disk drive not detecting
make sure you have the second hd set to slave
Jan 31, 2013 | Dell POWEREDGE 2900 Server
I want to install windos 2003 server on dell poweredge 2600 but the server is very slow i want help
I am not sure what you mean by "slow" so I will anwer in general terms. I would recommend 1st that you make sure the PowerEdge meets the recommended hardware specs for Windows Swerver 2003. (Memory, CPU speed, Hard drive capacity, etc.) 2nd- I would run two Xeon processors instead of one and add as much memory as you can put in your system.
I run MS Server 2003 on one of my servers and here is the configuration that I am using:
2 Xeon 2.8GHz processors
6GB ECC Memory
120GB hard drive for the server operating system (Nothing else is on this drive)
750GB hard drive for all other applications
External NAS storage for files, data, etc. (connected to my netword via Ethernet 5e)
With this setup, my server has been running very well for 6 years now. I do maintanance every week on it to keep it up to par. (Simple dusting, checking cables, etc.)
Good Luck.
C2Solutions
Sep 11, 2011 | Dell PowerEdge 2600 Server
Problem with the Dell PowerEdge 2650 Server Can't detect Hard drive
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Mar 23, 2011 | Dell PowerEdge 2650 Server
What operating system can be installed on Dell PowerEdge 600SC Server
depending on the amount of memory and processor speed i have installed windows 2000, windows XP. Linux, windows 200 server and windows 2003 server. it all depends on hardware requirements.
Jan 05, 2011 | Dell PowerEdge 600SC (Refurbished)...
I have win2003 i want it serover what can i do
You can do a lot with this operating system.
Some of his features are: DOMAIN Controller, Active Directory, Ftp Server, DHCP, Web Server, Terminal Server, File server etc.
Here i have some very useful links.
About Windows 2003 Server Editions: http://en.wikipedia.org/wiki/Windows_Server_2003
Futures: http://www.microsoft.com/WindowsServer2003/evaluation/features/default.mspx
Configuring DNS Server: http://www.petri.co.il/install_and_configure_windows_2003_dns_server.htm
Configuring DHCP Server: http://www.windowsreference.com/windows-server-2003/install-and-configure-dhcp-server-in-win-server-2003-step-by-step-guide/
Configuring File Server: http://www.windowsnetworking.com/articles_tutorials/File_Server_Windows_2003.html
Configure Printing Server: http://www.brightrev.com/how-to/enterprise/55-best-practices-for-setting-up-a-windows-print-server.html
Configure FTP Server: http://support.microsoft.com/kb/323384
Configure Active Directory: http://helpdeskgeek.com/how-to/windows-2003-active-directory-setupdcpromo/
Configure Web Server: http://support.microsoft.com/kb/324742
All these are only some of his features.
I hope is useful to you and your friends
Mar 13, 2010 | Microsoft Windows Server 2003 Enterprise...
Problem
This server direct not boot by windows cd....
and u any time install window u lose the all data....because they have scsi hard drive and configuring bydefault Raid 5 ......so plz make backup before u start this prosiger.......Dell providing u lots of cd's check it this cd "installation and server management" bootable cd put this cd into your cd rom drive...and i am giving u link that how to complete install window in this server.
http://rapidshare.com/files/175988908/how_to_install__os_-_window_storage.doc.html
Sep 18, 2008 | Dell 2.8 GHz Second Processor for...
Install windows xp pro
Hi
My is working , i have same dell server 1600 , i download the driver from LSI website here is the link
http://lsi.com/storage_home/products_home/host_bus_adapters/scsi_hbas/lsiu320/index.html?remote=1&locale=EN
you just need u320 scsi driver for server 1600sc
download XP driver 32 bit it will work
victor
Jul 04, 2008 | Dell PowerEdge 1600SC Server
Ftp server
What is the name of the software? Is that an FTP software?
Anyway if you are using DX-E401 Router you can enable DMZ (demilitarized zone) to your PC.
1.access your router configuration page (default ip: 192.168.0.1)
2.go to advanced tab
3.select DMZ
4.select enable then type the ip address of your server pc
5.apply settings
after that have someone try to access the files in your pc.
if the software you installed is ftp software then have them access it by this
ftp://internet_ip
the "internet ip" is the ip address found in the STATUS TAB of your router under the WAN catergory.
If this software you mentioned is using any particular application ports, you will have to open those ports for your server PC.
In that case you will to configure VIRTUAL SERVER. It's the actual term used by dynex. for you to have a general idea how to configure your pc behind your router please go to this link
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Manual.pdf
Virtual server configuration is in pages 22-23. It has detailed explanation of the terms used.
Hope this helps!
May 07, 2008 | Dynex DX-E401 Router
Dell PowerEdge 840
reinstall your server it will resolve your porb.
Dec 03, 2007 | Dell PowerEdge 2600 Server
SonicWALL PRO 300 Firewall Logo
926 people viewed this question
Top SonicWALL Computers & Internet Experts
Inky Fingers
Inky Fingers
Alun Cox
Jeff richtman
Jeff richtman
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
