Techwood tvoes the sound keep going off on my techwood tv
Sound keeps going off
3 Suggested Answers
  • 3 Answers
SOURCE: plasma tv techwood 4210
hi the most common fault on this tv is what you describe .i fixed mine by replacing the capacitor (1uf 630vdc) at location c19 on the power board .. cost for this component less than 90p
Posted on Mar 16, 2008
walesarumi
  • 6993 Answers
SOURCE: techwood tv keeps turning itself off
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Nov 12, 2011
How do fit a wall bracket on 50 in techwood tv
TECHWOOD 50inches TV Wall Mount Bracket TV BRACKETS TV WALL BRACKETS...
You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
Semper Fi,
Z
Jan 30, 2018 | Televison & Video
My Techwood TV, The sound keeps going off, Turn tv off wait 30 secs turn on again, sound works for another 10 mins, Then repeat over & over
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Mar 09, 2017 | Televison & Video
Techwood tv volume going back down
I've got this problem these fixing only work for a sort time! Volume just turns itself down?! Anyone no the real fix?
Jul 03, 2012 | Televison & Video
How can I listen to audio from Techwood TV/DVD player through home stereo? I have connected a red&white stereo lead & selected aux on my stereo, but sound still just comes out from the TV. Any help is
Make sure that you are using the Audio Out ports (not one of the audio in). Next go into the menu. Select the Audio setup option and see if there is a line for enabling the external speakers. (Often this corresponds to turning off the internal speakers but not always.)
I hope this helps. I'm not familiar with the specs of Techwood TV models. Some TVs only have an headphone/earphone (3.5 mm) jack as their audio out. In that case, you'll need an adapter to convert the RCA audio to the headphone jack.
Dec 09, 2011 | Televison & Video
Techwood 400 watt Stereo Receiver PLR85
I have a Techwood PLR85 spearkers will not play, have replaced bus fuses 6v&7v fuses keep blowing out and still nothing
Feb 20, 2008 | Audio Players & Recorders
Plasma tv techwood 4210
Oct 11, 2007 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
